I keep getting this warning and not sure how to handle it other than wait for an update or filter out the log. any suggestions on this? I am fully up to date with HA 2024.3.0
Logger: homeassistant.helpers.frame
Source: helpers/frame.py:156
First occurred: 6:04:34 AM (1 occurrences)
Last logged: 6:04:34 AM
Detected that custom integration ‘hacs’ accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at Issues · hacs/integration · GitHub
I’m having some problems with Home Assistant not upgrading beyond version 11.1, and I’m getting the same error message, is there any possibility that there is a connection?
I’ve raised this on the forum buy haven’t had much success, is there any likelihood that this could be related?
I think that the consensus is that this is a “for your information” message that’s not currently causing any problems, and will get sorted out by the original creator in the next version.
