Hi there,
I’ve noticed that the following warning will be logged since some time:
Logger: homeassistant.components.utility_meter.sensor
Source: components/utility_meter/sensor.py:456
Integration: Verbrauchszähler (documentation, issues)
First occurred: 18. April 2023 um 19:29:06 (140 occurrences)
Last logged: 04:52:13
oilfox_fuelused_daily received an invalid state change coming from sensor.oilfox_fuelused (unavailable > 107.0)
oilfox_fuelused_weekly received an invalid state change coming from sensor.oilfox_fuelused (unavailable > 107.0)
oilfox_fuelused_monthly received an invalid state change coming from sensor.oilfox_fuelused (unavailable > 107.0)
oilfox_fuelused_quarterly received an invalid state change coming from sensor.oilfox_fuelused (unavailable > 107.0)
oilfox_fuelused_yearly received an invalid state change coming from sensor.oilfox_fuelused (unavailable > 107.0)
These Sensors are Utility_meters which I have created per Configuration yaml and not per helper…
The Configuration is pretty straight:
# Oilfox
# Kachelofen
oilfox_fuelused_daily:
unique_id: 'oilfox_fuelused_daily'
source: sensor.oilfox_fuelused
cycle: daily
oilfox_fuelused_weekly:
unique_id: 'oilfox_fuelused_weekly'
cycle: weekly
oilfox_fuelused_monthly:
unique_id: 'oilfox_fuelused_monthly'
cycle: monthly
oilfox_fuelused_quarterly:
unique_id: 'oilfox_fuelused_quarterly'
cycle: quarterly
oilfox_fuelused_yearly:
unique_id: 'oilfox_fuelused_yearly'
cycle: yearly
Unfortunately, I cannot see any information in the documentation on how to add something like a “availability” statement that would prevent this from happening.
The Interesting thing here is, that about 20 mins before this log entry was written, it seems that the integration could not connect to the server.
Therefore, the source sensor became “unavailable”:
Logger: custom_components.oilfox.UpdateCoordinator
Source: helpers/update_coordinator.py:193
Integration: OilFox (documentation, issues)
First occurred: 18. April 2023 um 19:59:15 (13 occurrences)
Last logged: 04:32:04
Timeout fetching oilfox data
Oilfox is a custom component … but I don’t think that this should be an issue here atm…
Do you have an idea on how I could prevent this from happening?
