I’ve happened to notice that my non-admin user account cannot access the logbook (via either the mobile app on Android or using Chrome with the same user).
I believe this has come about recently, possibly with the update to 0.112.x (although i cannot be 100% sure).
I get an error logged:
Logger: homeassistant.components.websocket_api.http.connection.139629326808784
Source: components/websocket_api/connection.py:97
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 17:16:06 (1 occurrences)
Last logged: 17:16:06
Error handling message: Unauthorized
I’ve not seen any changes in the documentation or the release notes to suggest this was expected, and the Logbook sidebar menu item is still offered to non-admin users.
Yeah, this was an unintentional bug that is being fixed.
The Logbook now shows which user who made the change such as “Living Room Light turned on (Suzy)”, but it used an admin-only API to retrieve that user info.
It’s being updated to use Persons instead of Users, which will make it work for all account types.
Enhanced permissions (ACL system) is planned, but will likely take a while as there’s a significant amount of work involved, and other things have priority at the moment.
But you can sort of do what you want with Custom Sidebar by Villhellm. That has an “exceptions” feature where you can hide sidebar items from certain user accounts. I’m pretty sure it simply removes it from the sidebar though - if the user knew the URL(s) they’d still be able to type it in and access those pages directly.
I have the same problem after the April updates, a non-admin user cannot access to the logbook.
The previous condition was very good because users who were not administrators could view the history of events from logbook. I am waiting for the next update that will fix this error
Unfortunately, today’s update (core-2021.4.6) did not solve the problem. Still a non-admin user cannot access to the logbook. I have a message in my log:
ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140555355526384] Error handling message: Unauthorized
