Logbook and History empty but database is Ok
I just did a fresh install of Hass.io on Docker Ubuntu, but the Logbook and history stay empty.
I have this warning in the log
2018-10-19 16:31:43 WARNING (Recorder) [homeassistant.components.recorder.migration] Database requires upgrade. Schema version: None
I deleted home-assistant_v2.db and reboot didn’t fix.
Then I looked at the database looks:
root@virtualubuntu:/usr/share/hassio/homeassistant# sqlite3 home-assistant_v2.db “PRAGMA integrity_check”
ok
sqlite> SELECT * FROM schema_changes;
1|6|2018-10-19 06:29:02.801060
sqlite> SELECT count(*) from states;
48
Looks like the recorder is properly writing, data looks good inside.
I enable DEBUG log level on recorder and get
2018-10-19 17:07:53 DEBUG (Recorder) [homeassistant.components.recorder] Connected to recorder database
2018-10-19 17:14:27 DEBUG (SyncWorker_1) [homeassistant.components.recorder.util] converting 84 rows to native objects took 0.023768s
2018-10-19 17:14:29 DEBUG (SyncWorker_2) [homeassistant.components.recorder.util] converting 84 rows to native objects took 0.007865s
But somehow HA can not access to this data
Thanks in advance for your help
L.
Update to 0.80.3
It work indeed. Thx a lot!
