Logbook duplicate entries, help
Since ~2 hours ago, at which time I restarted my home assistant container. My logbook began to show duplicate entries. What can I do to fix this?
I tried restarted my raspi, problem still persists.
I am on Home assistant version 0.117.6, Frontend version: 20201021.4 - latest
I haven’t tried upgrading the home assistant to the latest because I ran into problem last time I did.
Don’t be bothered by lots of pir entries, I was trying to fine tune the timing setting in the board and my code inside appdaemon.
Did you try to clear the browser cache?
I just did, problem is still there. duplicate entries appear in Home assistant android app as well. So it could be server side problem?
I have 2 HA container in my docker, version 0.117.6 and the other one is later version 0.118 (if i remember correctly). I’ve just checked my container status through portainer. It turns out there are 2 instances of HA container running at the same time. After I stopped one of the HA container, I reboot my raspi. Looks like the duplicate entries problem is gone now.
Hope this helps someone who has the same problem as mine.
