Hello, I created and input_number to track thermostat set point changes. For some reason the logbook even is not shown with the graph.
From the Logbook page
This is working as intended.
Logbook entries in the more-info pop-up card are only shown for non-numeric sensors.
Ah ok thanks for the info. Do you happen to know if they are also not shown in the Logbook Card?
I ended up solving my problem by removing the unit of measurement from the input_number. So I don’t think it has to do with non-numeric sensors for my case.
Removing the unit_of_measurement
makes it a non-numeric entity. So it most definitely does, you just proved it.
What type of entity is that?
A template sensor with a state = a state of input_select.
Just had a look at mine. It appears all sensor domain entities do not have a logbook entry list in the more info pop up. Only binary sensors do.
I find this not correct.
I find your statement confusing.
I reported that I do not see logbook entries for non numeric sensors in the more info pop-up. Confirming your observation.
You then link to an issue that says the same thing and say I am incorrect.
So how is my observation incorrect?
I find the current implementation “logbook is not displayed for a sensor w/o uom” incorrect.
Fine, me too, but the way you replied to a direct quote of me makes it look like you disagree with me when I said that.
I see, that could be confusing, agree.
