Created a fresh install for an RPI 3 using the latest hassbian download image. The installation completed successfully and I am able to access via ssh as well as access the frontend. Switch entities I added for test purposes (rpi relay board with rpi-gpio component) work correctly…The problem is that the logbook, history and recorder components fail to load. Inspection of /home/homeassistant/.homeassistant reveals the db file is not created. Only 11% of available space is in use.
Setup failed for logbook: Could not setup all dependencies.
3:51 PM setup.py (ERROR)
Unable to setup dependencies of logbook. Setup failed for dependencies: recorder
Press the button to load the full Home Assistant log.
2018-08-06 20:51:39 ERROR (Thread-4) [homeassistant.util.package] Unable to install package sqlalchemy==1.2.10: Exception:
File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
chunked=chunked)
File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 391, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 387, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
response.begin()
File "/usr/lib/python3.5/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.5/http/client.py", line 266, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/srv/homeassistant/lib/python3.5/site-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/commands/install.py", line 353, in run
wb.build(autobuilding=True)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/wheel.py", line 749, in build
self.requirement_set.prepare_files(self.finder)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 620, in _prepare_file
session=self.session, hashes=hashes)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/download.py", line 821, in unpack_url
hashes=hashes
File "/srv/homeassistant/lib/python3.5/site-packages/pip/download.py", line 659, in unpack_http_url
hashes)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/download.py", line 853, in _download_http_url
stream=True,
File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get
return self.request('GET', url, **kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/download.py", line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request
resp = self.send(prep, **send_kwargs)
File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send
r = adapter.send(request, **kwargs)
File "/srv/homeassistant/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send
timeout=timeout
File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py", line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
2018-08-06 20:51:39 ERROR (MainThread) [homeassistant.requirements] Not initializing recorder because could not install requirement sqlalchemy==1.2.10
2018-08-06 20:51:39 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Could not install all requirements.
2018-08-06 20:51:39 WARNING (MainThread) [homeassistant.components.http] You have been advised to set http.api_password.
2018-08-06 20:51:39 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of history. Setup failed for dependencies: recorder
2018-08-06 20:51:39 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not setup all dependencies.
2018-08-06 20:51:44 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of logbook. Setup failed for dependencies: recorder
2018-08-06 20:51:44 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not setup all dependencies.
