I’ve always had problems with my raspberry pi 4 running Home Assistant Supervisor 2022.06.dev3004 on an USB flash drive. Before the USB flash drive, I used a Micro SD card, same problem: there are times I need to unplug the raspberry to get everything working again. Every 2-4 months I guess.
This is really uncomfortable, so I’m trying to solve this for some time now. I even reinstalled my complete setup (made a backup of the initial setup without installing anything this time) and I stil got a logbook with errors. Errors that aren’t suppose to happen I guess. But I have really no clue on how to solve them. I tried to Google them, sometimes find info, but mostly too technical for me.
Any tips/ideas on how to solve these errors? Thanks!
My logbook:
:0:0 Script error.
12:42:33 – (FOUT) components/system_log/__init__.py - bericht kwam voor het eerst om 4 juli 2022 21:10:07 en verschijnt 89 keer
[0x9036:1:0x1000]: Couldn't get list of groups: [0x9036:1:0x1000]: Message send failure
12:42:33 – (WAARSCHUWING) Zigbee Home Automation - bericht kwam voor het eerst om 4 juli 2022 21:16:41 en verschijnt 15 keer
No response to 'Command.aps_data_indication' command with seq id '0xa3'
12:38:44 – (WAARSCHUWING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py - bericht kwam voor het eerst om 4 juli 2022 21:50:04 en verschijnt 68 keer
Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=16 read=polling write=<idle, bufsize=0>>
08:07:42 – (FOUT) /usr/local/lib/python3.9/site-packages/async_upnp_client/ssdp.py - bericht kwam voor het eerst om 5 juli 2022 04:43:41 en verschijnt 14 keer
Unable to find referenced entities number.philips_ltw010_3849bf03_level_start_up_current_level or it is/they are currently not available
5 juli 2022 17:07:31 – (WAARSCHUWING) helpers/service.py - bericht kwam voor het eerst om 4 juli 2022 21:09:19 en verschijnt 7 keer
Can't connect to ESPHome API for slimmelezer @ 192.168.1.149: Error connecting to ('192.168.1.149', 6053): [Errno 111] Connect call failed ('192.168.1.149', 6053)
5 juli 2022 13:48:53 – (WAARSCHUWING) /usr/local/lib/python3.9/site-packages/aioesphomeapi/reconnect_logic.py - bericht kwam voor het eerst om 5 juli 2022 03:11:32 en verschijnt 2 keer
Login attempt or request with invalid authentication from 192.168.1.186 (192.168.1.186). (Mozilla/5.0 (iPhone; CPU iPhone OS 15_5 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 15.5.0) Mobile/HomeAssistant, like Safari)
5 juli 2022 00:32:46 – (WAARSCHUWING) HTTP
number.ikea_of_sweden_tradfri_bulb_e27_wsopal_980lm_2fe69bfe_level_on_level: Could not set value: [0x274e:1:0x0008]: Message send failure
5 juli 2022 00:15:10 – (FOUT) Zigbee Home Automation - bericht kwam voor het eerst om 5 juli 2022 00:15:09 en verschijnt 2 keer
Error with socket 12 (('::', 5353, 0, 0))): [Errno 99] Address not available
4 juli 2022 22:04:56 – (WAARSCHUWING) /usr/local/lib/python3.9/site-packages/zeroconf/_logger.py - bericht kwam voor het eerst om 4 juli 2022 21:45:36 en verschijnt 2 keer
Cancelled topology scanning task
4 juli 2022 21:28:52 – (WAARSCHUWING) /usr/local/lib/python3.9/site-packages/zigpy/topology.py
[2789392952] Error handling message: Unknown error (unknown_error)
4 juli 2022 21:28:41 – (FOUT) Home Assistant WebSocket API
Unexpected transmit confirm for request id 239, Status: TXStatus.SUCCESS
4 juli 2022 21:15:48 – (WAARSCHUWING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/zigbee/application.py
Setting state for entity shellyswitch25-98CDAC1EA04B failed, state: {'go': 'close'}, error: ClientConnectorError(ConnectionKey(host='192.168.1.252', port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=1759808034), OSError(113, "Connect call failed ('192.168.1.252', 80)"))
4 juli 2022 21:10:16 – (FOUT) Shelly - bericht kwam voor het eerst om 4 juli 2022 21:10:16 en verschijnt 2 keer
