Hi.
I need help pls with an automation that is not captured in logbook.
Logbook captures automations fine except for one. This automation calls a script that converts seconds to a friendly time. This code is called often so it is kept in a script:
- service: script.friendly_time_from_seconds_script
timeInSeconds: >-
{{ ( as_timestamp(now())| int ) - (as_timestamp(states('input_datetime.time_left_house')) | int ) }}
response_variable: friendlyTime
- service: input_text.set_value
entity_id: input_text.sms_message
value: >-
You were out for {{ friendlyTime.value }}.
In logbook only the step details for the “script.friendly_time_from_seconds_script” script is captured. The automation that calls it (that I want to debug) does not appear.
If I remove the service calling the script above, then the calling script is captured in logbook.
