Hi!
since a few weeks I saw the follow entrys in my Logbook
Any Ideas?
regards
René
Using:
- Home Assistant 2021.2.1
- Operating System Home Assistant OS 5.11
- supervisor-2021.02.5
Hi!
Any Ideas?
regards
René
Using:
Your host does not have a battery backed real time clock, restarted and no network is available or NTP network time client was unable to get time from the internet.
All my Hosts have the correct datetime:
also all Unfi switches and controller
here a new LOG from this morning:
Hi! ok got it!
its a bug in the Unfi-Integration.
I disabled the “Uptime sensors for network clients”
Isn’t this a timestamp represenatation of uptime in seconds? What values do the actual sensor show as a value under Developer Tools -> States?
hmmm interesting, what are your versions off HA, etc ?
in my Unfi Controller all uptime are OK:
but on the way to HA something gets wrong. So I though it is the UniFi Integration…
I’m on the latest version, but I don’t think that makes a difference.
Did you check what the actual state is under Developer Tools -> States in HA?
As I suspected, the uptime is represented as a tinestamp.
What do they show if you add them to the frontend in an entities card for example?
You could ask the dev of the integration to change it to show the time it came online, this way it doesn’t need to change the sensors every second and decreases the load on the system (even though this should be neglectable in this case).
I open a ticket:
