Dear,
I have quite some errors in my log related to my circadian lighting compenent. Errors are mainly due to the fact that some of these lights are off (power-off) and can’t be updated at that moment. This is fine for me.
However, I would like to skip these errors in my logfile. I added following in my configuration.yaml
logger:
default: warn
logs:
homeassistant.components.media_player: error
homeassistant.components.http: warning
custom_components.circadian_lighting: critical
but this doesn’t seem to work as I still get following:
Logger: homeassistant.util.logging
Source: util/logging.py:105
First occurred: 6 November 2021, 15:09:30 (229 occurrences)
Last logged: 09:59:31
Exception in _update_switch when dispatching 'circadian_lighting_update': () Traceback (most recent call last): File "/config/custom_components/circadian_lighting/switch.py", line 323, in _update_switch await self._adjust_lights(lights or self._lights, transition) File "/config/custom_components/circadian_lighting/switch.py", line 344, in _adjust_lights if not self._should_adjust(): File "/config/custom_components/circadian_lighting/switch.py", line 339, in _should_adjust if self._is_disabled(): File "/config/custom_components/circadian_lighting/switch.py", line 333, in _is_disabled and self.hass.states.get(self._disable_entity).state in self._disable_state AttributeError: 'NoneType' object has no attribute 'state'
Am I missing something?
