I want to filter these messages from my log but I can’t figure out what to specify:
2024-04-27T13:23:25.197894-05:00 eem component [W][component:237]: Component atm90e32.sensor took a long time for an operation (57 ms).
2024-04-27T13:23:25.204239-05:00 eem component [W][component:238]: Components should block for at most 30 ms.
2024-04-27T13:23:34.826792-05:00 eem component [W][component:237]: Component atm90e32.sensor took a long time for an operation (70 ms).
2024-04-27T13:23:34.826792-05:00 eem component [W][component:238]: Components should block for at most 30 ms.
2024-04-27T13:23:37.545675-05:00 eem component [W][component:237]: Component atm90e32.sensor took a long time for an operation (59 ms).
2024-04-27T13:23:37.545675-05:00 eem component [W][component:238]: Components should block for at most 30 ms.
2024-04-27T13:23:37.622424-05:00 eem component [W][component:237]: Component atm90e32.sensor took a long time for an operation (56 ms).
2024-04-27T13:23:37.628228-05:00 eem component [W][component:238]: Components should block for at most 30 ms.
2024-04-27T13:23:38.098696-05:00 eem component [W][component:237]: Component atm90e32.sensor took a long time for an operation (71 ms).
2024-04-27T13:23:38.098696-05:00 eem component [W][component:238]: Components should block for at most 30 ms.
2024-04-27T13:23:48.993736-05:00 eem component [W][component:237]: Component atm90e32.sensor took a long time for an operation (56 ms).
My configuration contains this logger configuration:
logger:
baud_rate: 921600
level: INFO
logs:
atm90e32.sensor: ERROR
but it doesn’t stop the warnings from the atm90e32 component.
What should my logger entry look like to stop those messages (which come at the rate of 1/second)?
