The log message you’re seeing is related to a script in Home Assistant that uses the trigger_update_coordinator. The error suggests that the script is missing a context when it is being run, and it is causing repetitive logging. The context parameter is used in Home Assistant scripts and automations to track who or what triggered the script (e.g., manual activation, automation trigger, etc.).
Here’s how you can troubleshoot and resolve this issue:
Steps to Fix:
Identify the Problematic Script:
The error points to a script using trigger_update_coordinator. Look at your Home Assistant scripts and automations that may involve an update coordinator or a periodic update mechanism.
If you know which script or automation this is, you can check its configuration.
Add Context to the Script:
In your script, when calling a service or another script, you can pass a context. For example:
Ensure the script is set to pass the appropriate context when being triggered, either by another automation or manually.
Check for Custom Integrations:
If you are using a custom integration that uses an UpdateCoordinator (such as integrations from HACS), verify that it is up to date. Sometimes, issues like this arise from bugs in custom components.
If you find that a specific custom integration is responsible, consider updating or reinstalling it.
Search Your Configurations for Trigger Update Coordinator References:
In your configuration files (configuration.yaml, scripts.yaml, automations.yaml), search for any references to trigger_update_coordinator or services being called without a proper context.
If you are calling scripts from automations, ensure they are passing the context correctly.
