I don’t see anything wrong with your config. Check setting it at runtime using logger.set_level as described in the docs and see if that helps, or perhaps provides additional logging to understand what’s going on.
I’ve noticed a similar problem after fiddling with the logs recently. Even after removing the logger: section entirely from the yaml (and rebooting, several times), my logs are still flooded with debug messages. I’m still at the beginning of trying to figure this out but wanted to post here in case there are any updates.
EDIT: I’m running the container, removing and rebuilding it got the default logs working again where restarting (either via the HA UI or docker restart) didn’t before. I also tried deleting my home-assistant_v2.db file before recreating the container, not sure if that was necessary or not.
Logger: homeassistant.helpers.entity
Source: components/tuya/__init__.py:255
First occurred: 2:40:34 PM (16 occurrences)
Last logged: 3:06:34 PM
Update for switch.02200490dc4f221617c6 fails
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 278, in async_update_ha_state
await self.async_device_update()
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 474, in async_device_update
raise exc
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/tuya/__init__.py", line 255, in update
self._tuya.update()
File "/srv/homeassistant/lib/python3.7/site-packages/tuyaha/devices/switch.py", line 16, in update
return self._update(use_discovery=True)
File "/srv/homeassistant/lib/python3.7/site-packages/tuyaha/devices/base.py", line 84, in _update
devices = self.api.discovery()
File "/srv/homeassistant/lib/python3.7/site-packages/tuyaha/tuyaapi.py", line 188, in discovery
response = self._request("Discovery", "discovery")
File "/srv/homeassistant/lib/python3.7/site-packages/tuyaha/tuyaapi.py", line 268, in _request
name, response_json["header"].get("msg", result_code), devId
File "/srv/homeassistant/lib/python3.7/site-packages/tuyaha/tuyaapi.py", line 292, in _raise_frequently_invoke
raise TuyaFrequentlyInvokeException(message)
tuyaha.tuyaapi.TuyaFrequentlyInvokeException: Method [Discovery] fails 1 time(s) using poll interval 60.0 - error: you can discovery once in 600 seconds
I have been having this problem for months and months… it seems that if at any time ive added a specific logging level to track something and then remove that config, it just stays at that level. So if my default level is ‘warning’, and i set a zha level to debug, and then i remove the zha setting, zha will stay at debug unless i explicitly set it to warning. My logs are FILLED with zigbee debug logs.
