I changed default to critical and error. I’m still getting a bunch of useless info as well as what I need. It’s a lot of text to sort through. Is there a way to get debug info only for these ?
You have to restart after changing these. Also, python logging is value based. Each severity has a value associated with it, when you set a logging level, everything above that severity is output.
Debug is the lowest. That means all other severity’s are output as well.
