Logger Questions
Hi all,
I have configured a lot of HP_ILO sensors to monitor my HP DL380 server:
The configuration is the following:
- platform: hp_ilo
    host: 192.168.0.XX
    username: XXXXXXX
    password: XXXXXXXX
    monitored_variables:
        #System Uptime
      - name: System Uptime
        sensor_type: server_power_on_time
        unit_of_measurement: 'min'
        #Ventilation
      - name: System Fan 1
        sensor_type: server_health
        unit_of_measurement: '%'
        value_template: '{{ ilo_data.fans["Fan 1"].speed[0] }}'
      - name: System Fan 2
        value_template: '{{ ilo_data.fans["Fan 2"].speed[0] }}'
      - name: System Fan 3
        value_template: '{{ ilo_data.fans["Fan 3"].speed[0] }}'
      - name: System Fan 4
        value_template: '{{ ilo_data.fans["Fan 4"].speed[0] }}'
      - name: System Fan 5
        value_template: '{{ ilo_data.fans["Fan 5"].speed[0] }}'
      - name: System Fan 6
        value_template: '{{ ilo_data.fans["Fan 6"].speed[0] }}'
        #Energy
      - name: Power Supply 2
        value_template: '{{ ilo_data.power_supplies["Power Supply 2"].status }}'
      - name: Power Supply 1
        value_template: '{{ ilo_data.power_supplies["Power Supply 1"].status }}'
      - name: Current Power
        sensor_type: server_power_readings
        unit_of_measurement: 'Watts'
        value_template: '{{ ilo_data.present_power_reading[0]}}'
        #Temperatures
      - name: Ambient Zone
        unit_of_measurement: '°C'
        value_template: '{{ ilo_data.temperature["Temp 1"].currentreading[0] }}'
      - name: CPU 1
        value_template: '{{ ilo_data.temperature["Temp 2"].currentreading[0] }}'
      - name: CPU 2
        value_template: '{{ ilo_data.temperature["Temp 3"].currentreading[0] }}'
      - name: Memory Zone 1
        value_template: '{{ ilo_data.temperature["Temp 4"].currentreading[0] }}'
      - name: Memory Zone 2
        value_template: '{{ ilo_data.temperature["Temp 5"].currentreading[0] }}'
      - name: Memory Zone 3
        value_template: '{{ ilo_data.temperature["Temp 6"].currentreading[0] }}'
      - name: Memory Zone 4
        value_template: '{{ ilo_data.temperature["Temp 7"].currentreading[0] }}'
      - name: Power Supply 1 Zone
        value_template: '{{ ilo_data.temperature["Temp 8"].currentreading[0] }}'
      - name: Power Supply 2 Zone
        value_template: '{{ ilo_data.temperature["Temp 9"].currentreading[0] }}'
      - name: I/O Board Zone 1
        value_template: '{{ ilo_data.temperature["Temp 10"].currentreading[0] }}'
      - name: I/O Board Zone 2
        value_template: '{{ ilo_data.temperature["Temp 11"].currentreading[0] }}'
      - name: I/O Board Zone 3
        value_template: '{{ ilo_data.temperature["Temp 12"].currentreading[0] }}'
      - name: CPU Zone 1
        value_template: '{{ ilo_data.temperature["Temp 19"].currentreading[0] }}'
      - name: CPU Zone 2
        value_template: '{{ ilo_data.temperature["Temp 20"].currentreading[0] }}'
      - name: CPU Zone 3
        value_template: '{{ ilo_data.temperature["Temp 21"].currentreading[0] }}'
      - name: CPU Zone 4
        value_template: '{{ ilo_data.temperature["Temp 22"].currentreading[0] }}'
      - name: I/O Board Zone 4
        value_template: '{{ ilo_data.temperature["Temp 23"].currentreading[0] }}'
      - name: Memory Zone 5
        value_template: '{{ ilo_data.temperature["Temp 24"].currentreading[0] }}'
      - name: Memory Zone 6
        value_template: '{{ ilo_data.temperature["Temp 25"].currentreading[0] }}'
      - name: Memory Zone 7
        value_template: '{{ ilo_data.temperature["Temp 26"].currentreading[0] }}'
      - name: System Zone
        value_template: '{{ ilo_data.temperature["Temp 29"].currentreading[0] }}'
      - name: I/O Board Zone 5
        value_template: '{{ ilo_data.temperature["Temp 30"].currentreading[0] }}'
The problem is that i´m getting a lot of theese Warn:
2019-07-23 09:58:35 WARNING (MainThread) [homeassistant.components.sensor] Updating hp_ilo sensor took longer than the scheduled update interval 0:00:30
2019-07-23 09:58:48 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.hp_ilo_system_uptime is taking over 10 seconds
2019-07-23 09:59:06 WARNING (MainThread) [homeassistant.components.sensor] Updating hp_ilo sensor took longer than the scheduled update interval 0:00:30
2019-07-23 09:59:11 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.hp_ilo_memory_zone_7 is taking over 10 seconds
2019-07-23 09:59:21 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.hp_ilo_memory_zone_1 is taking over 10 seconds
2019-07-23 09:59:37 WARNING (MainThread) [homeassistant.components.sensor] Updating hp_ilo sensor took longer than the scheduled update interval 0:00:30
2019-07-23 09:59:41 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.hp_ilo_i_o_board_zone_1 is taking over 10 seconds
2019-07-23 09:59:51 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.hp_ilo_system_fan_5 is taking over 10 seconds
I’ve tryed to create a logger exception under the following namespaces without success
logger:
  default: warn
  logs:
    homeassistant.helpers.entity: error
    homeassistant.components.sensor.hp_ilo: error
    homeassistant.components.hp_ilo: error
    homeassistant.components.sensor.EntintyId: error
None of this has worked, ¿anyone knows how to skip theese logging?
Kind regards
It’s not coming from either of those log names. The phrases in the square brackets are what the logger filters off of. So you’d have to use this followed by a restart.
logger:
  default: warn
  logs:
    homeassistant.components.sensor: error
Personally, I use this because it will show python errors only. Usually the rest of the errors can be worked out without needing the logs. Like through config checker and the sorts.
logger:
  default: critical
I understand that if i set logger like this:
logger:
  default: warn
  logs:
I would not receive warns from any sensor, the same with this one:
logger:
  default: critical
And I’m confortable with the rest of warning, they have helped me to solve and notice problems. I want to ignore only the ones coming from HP_ILO. It´s not critical info for me so it´s ok to take more time to refresh.
¿anyone has a clue if this is posibble?
It’s not possible because the way the filter works is based off the words inside the brackets. The section that is producing the warnings is: [homeassistant.components.sensor]. So the only way to remove them from the logs is to remove that section. The logging filter doesn’t search anything else, so this is literally your only option.
I’m not sure why you even want the warnings. They are almost always useless. Most components/integrations don’t even use that logging level.
I don´t agree that they are not usefull. I’ve used most of the time to trace components that don´t work properly.
I want all logs that are higher that INFO as i usually do. It’s a pitty the filter is done that way, i think it´s pretty normal to want certain level for a component but other for anotherone
