dump: all
level: VERBOSE
By clicking the LOGS button in esphome
How do I view just raw data and prevent esphome from trying to find a protocol to use. Because it is guessing wrong. I need just the millisecond data from the pulse widths.
dump: all
level: VERBOSE
What component are you talking about?
Infrared receiver?
Help us to help you.
Both or either ir or rf … Remote Receiver stuff
I have a need to see the raw pulse width data from rf and ir. I’ve been using a oscope to look at it now and then manually entering the data for raw transmission… Lots of work.
For instance a Honeywell fan ir remote recieves a guess of two different protocols nec and samsung. Both are wrong. But since it is guessing the logger skips showing the raw pulse width info.
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
# level: VERY_VERBOSE
# Enable Home Assistant API
api:
ota:
password: "3d240ca87586539769f60tyter"
wifi:
ssid: "ssid"
password: "password"
ap:
ssid: "Fallback Hotspot"
password: ergsgw54g4w
captive_portal:
remote_receiver: #working with A2ABTAE-d2
- id: RF_RCV
pin:
number: D4
tolerance: 60%
filter: 350us
idle: 4ms
buffer_size: 2kb
dump: rc_switch #all all is lots but good
dump:
- raw
dump:
- raw
Worked perfect
Now I am able to see Only the pulse width data from the LOGS button receiving through remote_receiver
This is sometimes needed if your remote is not using one of the protocols known to esphome for now.
The Faking an IR remote post is awesome.
The list of dump: options are here.
raw: Print all remote codes in their raw form. Useful for using arbitrary protocols.
Thank you Jpsy
