I struggle with writing a log file to my OneDrive.
I have set up a Backup procedure using the integration as described in https://www.home-assistant.io/integrations/onedrive and that works fine.
Next to this I use the File integration and Automation to log a Notification message.
Example YAML:
alias: Regen log
description: ""
triggers:
- trigger: time_pattern
hours: "*"
minutes: /5
conditions:
actions: - action: notify.send_message
metadata: {}
message: "{{ states("sensor.neerslagintensiteit") }}"
entity_id: notify.file_4
mode: single
That works fine too, but only to a local file (e.g. config/www/message.log)
I would like to be able to write the Notification to my OneDrive directory. Can somebody help?
