Logic bug or ESPHome bug?
I have this code below that I would like to trigger conditionally on a switch state, however it executes no matter what state the switch is in. The switch is a template switch (fans_auto_en). I’ve also tried to do it in the lambda with id(fans_auto_en).state but that yields the same result. The part that is not executing as intended is the if condition in the on_value block of the heatindex template sensor.
This automatation needs to be on the ESP device because wifi is spotty where it is located. It is using a ESP32U and is about 75m from the AP.
Any insite would be appreciated.
number:
    name: Trigger Fan On Temp
    min_value: 25
    max_value: 50
    step: 0.5
    optimistic: true
    restore_value: true
    on_value:
      then:
        - sensor.template.publish:
            state: !lambda 'return id(trigger_fan_on).state - id(offset_fan_off).state;'
    name: Offset Fan Off By
    min_value: 0
    max_value: 10
    step: 0.2
    optimistic: true
    restore_value: true
    on_value:
      then:
    name: Allow on after this hour
    min_value: 7
    max_value: 13
    step: 1
    optimistic: true
    restore_value: true
    name: Disallow on after this hour
    min_value: 13
    max_value: 22
    step: 1
    optimistic: true
    restore_value: true
time:
  - platform: sntp
    timezone: America/Toronto
    update_interval: 1hours
    on_time_sync:
      then:
        logger.log: Time Synced
    on_time:
      - seconds: 0
        minutes: 0
        hours: 22
        then:
          - switch.turn_off:
          - switch.turn_on:
output:
  - platform: gpio
    pin:
      number: ${plug1}
      inverted: true
switch:
  - platform: output
    name: Plug 1 Relay
    output: out_plug1
    name: Fan Automation Enabled
    optimistic: True
    restore_mode: RESTORE_DEFAULT_ON
    lambda: |-
      float c1 = -8.78469475556;
      float c2 = 1.61139411;
      float c3 = 2.33854883889;
      float c4 = -0.14611605;
      float c5 = -0.012308094;
      float c6 = -0.0164248277778;
      float c7 = 0.002211732;
      float c8 = 0.00072546;
      float c9 = -0.000003582;
      float T = id(temp).state;
      float R = id(hum).state;
      if (T >= 26.67 && R >= 40) {
        return (c1 + (c2 * T) + (c3 * R) + (c4 * T * R) + (c5 * pow(T,2)) + (c6 * pow(R,2)) + ( c7 * pow(T,2) * R) + (c8 * T * pow(R,2)) + (c9 * pow(T,2) * pow(R,2)));
      } else {
        return (T);
    unit_of_measurement: "°C"
    icon: "mdi:water-percent"
    device_class: "temperature"
    state_class: "measurement"
    on_value_range:
      - above: !lambda 'return id(trigger_fan_on).state;'
        then:
          - if:
              condition:
                  - switch.is_on: fans_auto_en
              then:
                - lambda: |-
                    auto time = id(sntp_time).now();
                    if(time.hour >= id(available_hour_start).state && time.hour <= id(available_hour_stop).state) {
                      id(plug1).turn_on();
          - switch.turn_on: plug1
      - below: !lambda 'return id(trigger_fan_on).state - id(offset_fan_off).state;'
        then:
          - switch.turn_off: plug1
Can You explain little bit more about
and how it executed actually.
I don’t want it to execute if the switch is off.
I couldn’t see the forest through the trees, this existed outside of the if
