Bayees
(Christian Bay)
February 26, 2021, 11:20am
87
The feature is there to change the config. It would be better if the discovery worked out of the box, but I am just not sure how to add it to the official release. I have looked into it, but not fully understand what it takes yet.
scaarup
(Scaarup)
February 26, 2021, 11:50am
88
The feature is there for you who are using mqtt for discovery - not me :).
For the zwave_js integration, if you don’t see these exposed as light entities in the 2021.3 release, please submit an issue.
scaarup
(Scaarup)
February 27, 2021, 3:48pm
90
Anyone got the blinking feature working? I cannot understand the manual regarding this - we are supposed to use the command class switch color set, some bits of the warm white …
I get one entity for each switch but it does not appear to control any lights in the switch.
Running core-2021.3.1
lauer
(Jesper Grann Laursen)
March 7, 2021, 7:59am
92
I have just added a blueprint for the matrix if you are using the new zwavejs integration.
It handle the actions for tap, 2x tap 3x tap, hold and release.
Let me know if you have any problems.
I stil need to find out how easy to handle colors and hold/release for dimming up and down.
Has anyone gotten the ZBA7140 to work with Home Assistant?
TRoager
(Thomas Roager)
April 9, 2021, 10:41am
94
Hello Mathias94
I have a pull request for Logic group devices on their github page. I am waiting on approval. And this device is in that pull request as well
That sounds great! Looking forward to be able to integrate the device, as it has some great potential.
So as far as I understand there is still no way to control the lights in the switch when using Z-wave js? The only way to do this so far are the methods mentioned by @ scaarup and @ Bayees
It would be a lot more elegant if the leds were exposed as regular .light in HA.
TRoager
(Thomas Roager)
April 15, 2021, 10:53am
98
Correct, it is a limitation in the integration i believe.
Which i have started an issue on
Bayees
(Christian Bay)
April 15, 2021, 11:22am
99
With my approach, I have the buttons as light entities. The only issue is when the button is lit with a specifik color and I press the button and it changes the LED to active. It will return to off and not notify HA.
Great - do you have a link so we can follow progress?
Have you tried setting “Internal LED control is disabled, only external” for the button under Pushbutton 1 LED indication in the config for the switch?
That is how I set it up with the old z wave integration and I controlled the light on/off and color from HA.
lauer
April 15, 2021, 11:47am
102
I just bought a ZBA, so I hope they add it soon. I can add the device to zwaveJS and get notification on click. But it still say unknown provider.
The PR seems to be this one, if others want to follow when its ready =)
zwave-js:master
← Roagert:logic_group_template
opened 12:27PM - 05 Apr 21 UTC
When its merged in and released, I will add it to my Blueprint, which support ZDB for now.
lauer
April 15, 2021, 1:22pm
103
Also. Have you seen this video. https://youtu.be/Rii9dQkxbDs
It could be Nice to have such app in home assistant.
TRoager
(Thomas Roager)
April 15, 2021, 1:56pm
104
Yes i have the device my self and it works on my site. It is working great with my implementation. That PR Will include that device.
TRoager
(Thomas Roager)
April 15, 2021, 5:20pm
105
This could be nice yes but that is an internally developed software from Logic Group i believe which could be nice for Home Assistant yes but i doubt that its straight forward.
lauer
April 17, 2021, 8:33pm
106
I was trying to set some configuration parameters for my ZDB5100 - but I see that the #14 is not included in the imported device config?
// Logic Group ZDB5100
// MATRIX Switch with Dimmer and Backlight
"manufacturer": "Logic Group",
"manufacturerId": "0x0234",
"label": "ZDB5100",
"description": "MATRIX Switch with Dimmer and Backlight",
"devices": [
"productType": "0x0003",
"productId": "0x0121"
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"supportsZWavePlus": true,
"paramInformation": {
"2": {
This file has been truncated. show original
Do you know why?
If you look in the OpenZwaveDB, the configuration parameter is defined and described.
<?xml version="1.0" encoding="utf-8"?>
<Product Revision="5"
xmlns="https://github.com/OpenZWave/open-zwave">
<MetaData>
<MetaDataItem name="Name">Matrix</MetaDataItem>
<MetaDataItem name="Description">MATRIX ZDB5100 is a dimmer wall switch module with four backlit pushbuttons. MATRIX is designed to fit into 1-module FUGA® wall boxes (Danish standard).</MetaDataItem>
<MetaDataItem name="OzwInfoPage">http://www.openzwave.com/device-database/0234:0121:0003</MetaDataItem>
<MetaDataItem name="ProductPage">https://logic-group.com/products/matrix-switches/</MetaDataItem>
<MetaDataItem name="ProductSupport">https://logic-group.com/contact/</MetaDataItem>
<MetaDataItem name="ProductPic">images/logicsoft/ZDB5100.png</MetaDataItem>
<MetaDataItem name="ProductManual">https://products.z-wavealliance.org/ProductManual/File?folder=&filename=Manuals/3399/MATRIX_ZDB5100_User_Manual_1_01-EN.pdf</MetaDataItem>
<MetaDataItem name="InclusionDescription">MATRIX’add/remove function is initiated by pressing a single time on the smallpushbutton(I) in the middle of the module (under the tangent cover), and the LED’s inpushbutton1 will start blinking.</MetaDataItem>
<MetaDataItem name="ExclusionDescription">MATRIX’add/remove function is initiated by pressing a single time on the smallpushbutton(I) in the middle of the module (under the tangent cover), and the LED’s inpushbutton1 will start blinking.</MetaDataItem>
<MetaDataItem name="ResetDescription">MATRIX can be factory reset by holding the smallpushbutton(I) in the middle of the module under the tangent cover, for at least 10 seconds.</MetaDataItem>
<MetaDataItem id="0121" name="ZWProductPage" type="0003">https://products.z-wavealliance.org/products/3399</MetaDataItem>
<MetaDataItem id="0121" name="FrequencyName" type="0003">CEPT (Europe)</MetaDataItem>
<MetaDataItem id="0121" name="Identifier" type="0003">ZDB5100</MetaDataItem>
<ChangeLog>
<Entry author="Dennis Staal - [email protected] " date="10 August 2019" revision="2">Initial Metadata Import from Z-Wave Alliance Database - https://products.z-wavealliance.org/products/3399/xml</Entry>
<Entry author="Jean-François Auger - [email protected] " date="15 January 2021" revision="3">Convert param 1 to a bitset</Entry>
TRoager
(Thomas Roager)
April 17, 2021, 8:52pm
107
All this should be resolved when the PR is approved. i think its a mistake when it was imported
