Just sharing a great link.
I have had a ZHC5010 wall switch for a couple of years. It has not been working very great.
After countless hours on google I found this: https://jope.eu/logichome-zhc5010-z-wave-switch/
After this the switch is working like a charm
From the authors site:
The problem is that home assistant needs to be configured to properly understand the multi channel messages. To do this follow below steps.
- Note down the node id for you wall switch and your controller.
- In Home Assistant click āServicesā under āDeveloper Toolsā.
- In service select zwave.change_association.
- In Service Data key in below. Node_id is the node id of you wall switch. Target_node_id is the node id of you controller. Click āCall Serviceā.
āassociationā:āaddā,
ānode_idā:2,
āgroupā:2,
ātarget_node_idā:1,
āinstanceā:1
}- Repeat step 4 with group 7, 12 and 17.
- Change the Service Data to below
āassociationā:āremoveā,
ānode_idā:2,
āgroupā:2,
ātarget_node_idā:1,
āinstanceā:0
}- Repeat step 7 with group 7, 12, and 17.
With above procedure you should now be able to use the 4 switches in home assistant.
