Hello Community!
I’m trying to develop an automated heating control in my house. I use a Sonoff TH and a valve actuator for each radiator. I created a climate/thermostat in Home Assistant for each and it works as expected. Switches are automatically controlled by Home Assistant based on the temperature read from the sensor.
But I need an extra switch to control the boiler, I use a modified Sonoff Basic which when turned on, starts the boiler, and when turned off, stops the boiler. So far so good on the hardware part.
What I can’t seem to understand how to program in Home Assistant, is a kind of logic “OR” function to combine the switch states of each radiator. So basically all I need:
- whenever any radiator’s switch is ON, turn the boiler ON
- whenever all radiator switches are OFF, turn the boiler OFF
Actually this is an OR logical operation of all the radiator switches, and the result should actuate the switch of the boiler. More easily: at any time if there’s at least one radiator switch in ON state, keep the boiler in ON state. Only turn off the boiler when all the radiator switches are OFF.
Any ideas how to implement this?
I looked at triggers and templates but couldn’t figure out how to do it. I don’t see how to prevent turning off the boiler when a radiator goes off, but there are other radiators still on.
Thanks in advance for your help.
