Hey folks, I’ve searched and found a few posts on this but haven’t found an answer that has worked.
I access configurator from another machine. I use Configurator to “Restart HASS” I get a notification in Home Assistant:
Login attempt or request with invalid authentication from 127.0.0.1
If I add this to configuration.yaml, I get an error and Home Assistant won’t start:
homeassistant:
auth_providers:
- type: trusted_networks
trusted_networks:
- 127.0.0.1/16
Error at startup: Invalid configuration for auth provider trusted_networks: not a valid value @ data[‘trusted_networks’][0]. Got ‘127.0.0.1/24’
I’ve also tried playing with the configurator.py file and adjusting:
USERNAME = xxxxx
PASSWORD = xxxxx
Do these need to be in quotes or anything?
Thanks in advance!
