Login attempt failed: how to track or understand?
anyone recognize this IP address: 45.91.57.206.
as of late I see this several times a day:
of course, there’s nothing more in the logs…
Apparently not one of the internal ip addresses, or my mobile provider. Can’t relate this to anything else. only thing else happening in the log around 3 hours ago was
2021-04-01 06:49:34 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.essen_roosendaal fails
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 277, in async_update_ha_state
    await self.async_device_update()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 473, in async_device_update
    raise exc
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/components/nmbs/sensor.py", line 273, in update
    if connections is None or not connections["connection"]:
KeyError: 'connection'
but that issue with the nmbs sensor has been going on since its inception, and is a long standing issue, and, never caused this error before.
please let me know what you’d do?
thanks
https://tools.tracemyip.org/ip_addresses--ipv4/45.91.57.0-45.91.57.255
I have no dealings with them…guess I’ll add this to the(a?) block list. Do we have a block list other then automatic the ip_bans.yaml?
happened automatically…
still, nothing in the logs. Wonder if this will cause havoc now…
wait, unless, could this be it:
2021-04-01 23:38:58 ERROR (SyncWorker_52) [homeassistant] Error doing job: CommandResult exception was never retrieved
  File "/usr/local/lib/python3.8/site-packages/mpd/asyncio.py", line 277, in __run
    await result._feed_from(self)
  File "/usr/local/lib/python3.8/site-packages/mpd/asyncio.py", line 44, in _feed_from
    line = await mpdclient._read_line()
  File "/usr/local/lib/python3.8/site-packages/mpd/asyncio.py", line 345, in _read_line
    line = await self.__readline()
  File "/usr/local/lib/python3.8/site-packages/mpd/asyncio.py", line 318, in __readline
    data = await self.__rfile.readline()
  File "/usr/local/lib/python3.8/asyncio/streams.py", line 540, in readline
    line = await self.readuntil(sep)
  File "/usr/local/lib/python3.8/asyncio/streams.py", line 632, in readuntil
    await self._wait_for_data('readuntil')
  File "/usr/local/lib/python3.8/asyncio/streams.py", line 517, in _wait_for_data
    await self._waiter
  File "/usr/local/lib/python3.8/asyncio/selector_events.py", line 848, in _read_ready__data_received
    data = self._sock.recv(self.max_size)
OSError: [Errno 113] Host is unreachable
