Login attempt failed over and over again
So i just made a fresh install of Home assistant Core. Its running on a VM in proxmox. I also have a Nabu Casa Cloud subscription to make it a bit easier for using the Home Assistant App outside of my network. I have an Iphone that is running the Home assistant app everything is working fine i can use the app inside and outside of local network. But for some reason i keep getting these “login attemt failed” messages coming from my phones local IP. And in my home-assistant.log file i keep getting these logs
"2023-01-11 22:01:19.535 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.77.149 (192.168.77.149). Requested URL: ‘/auth/token’. (HomeAssistant-Extensions-PushProvider/2022.10.1 (io.robbie.HomeAssistant.PushProvider; build:2022.424; iOS 16.1.2) Alamofire/5.4.4)
Can i get any kind of help with this problem?
+1
I am getting almost identical error under the same circumstances:
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:129
Integration: HTTP (documentation, issues)
First occurred: 4:19:52 PM (4 occurrences)
Last logged: 4:20:12 PM
Login attempt or request with invalid authentication from 192.168.5.145 (192.168.5.145). Requested URL: ‘/auth/token’. (HomeAssistant-Extensions-PushProvider/2023.12.1 (io.robbie.HomeAssistant.PushProvider; build:2023.508; iOS 17.2.0) Alamofire/5.6.4)
I don’t use Nabu Casa for remote access, but now and then I get pestered by this too. Luckily it goes away by itself after a few hours. I have the app in a handful of devices.
Anytime I have gotten that it is the HASS.agent that got it’s long-lived access tokens removed. Making a new token and applying it in the agent has always fixed it. Both of those look like internal IP addresses so it is something on your local network that is trying to log in. Hope that helps.
