"login attempt failed"
Would love to be rid of these bogus notifications.
Any new ideas on this old problem?
More info please? Logs? I only have visual code trying to log in. And it started happening when I moved from http to https. So it has something to do with that in my case.
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:124
Integration: HTTP (documentation, issues)
First occurred: December 8, 2021, 7:56:31 AM (1 occurrences)
Last logged: December 8, 2021, 7:56:31 AM
Login attempt or request with invalid authentication from 192.168.0.183 (192.168.0.183). (HomeAssistant/Android 2021.10.0-761)
It’s coming from my phone where I run the HA app. The phone app never indicates a logon failure and there’s no reason it should. But this happens every few days.
i have the same thing all the time, i just ignore the message
Get this on my Chromebook a lot, mostly if it is waking up from sleep and the Home Assistant webpage is left open (and active) while the Chromebook is reconnecting to WiFi. In this case - it actually signs me out of Home Assistant and I have to go through the login process again.
Same issues “login attempt failed”
Hope my LOG will help
Log shows that message daily for both my smartphones (they load home assistant, but maybe there are some occasional internal hass problems…?) connects through router (192.168.1.1):
2022-02-01 21:04:19 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.1 (192.168.1.1). (HomeAssistant/Android Redmi Note 9 Pro 2022.1.1-1890)
I’ve got home URL http://192…:8123/
and external link - also not https = http://hass…com:8123/
