Login attempt or request with invalid authentication from 192.168.1.# after setting up NGINX
I had a working copy of HA setup and went to setup nginx proxy. Everything seemed to work correctly, I was able to login, add Lovelace cards etc, but when I try to edit an automation, I find the error “Login attempt or request with invalid authentication from 192.168.1.#” and get error 401.
Note: this is seutp w/ Docker/HASS
Here is my configuration.yaml:
http:
  server_host: 127.0.0.1
  base_url: https://url
  use_x_forwarded_for: true
  trusted_proxies:
    - 127.0.0.1
    - 192.168.1.0/24
NGinx:
websockets-proxy.conf:
cat << 'EOL'>/etc/nginx/websocket-proxy.conf
proxy_http_version      1.1;
proxy_set_header        Upgrade            $http_upgrade;
proxy_set_header        Connection         "Upgrade";
proxy_set_header        Authorization      "";
proxy_read_timeout      86400;
proxy_set_header        Host               $host;
proxy_set_header        X-Real-IP          $remote_addr;
proxy_set_header        X-Forwarded-Server $host;
proxy_set_header        X-Forwarded-For    $proxy_add_x_forwarded_for;
proxy_redirect          off;
EOL
site.conf:
location / {
        proxy_pass              http://localhost:8123/;
        include                 /etc/nginx/websocket-proxy.conf;
Can anybody help me get this sorted out?
Well I had existing websocket-proxy.conf from a previous program and never had issues reusing it, but I copied the NGINX config from the docs word for word and it works now.
cat << 'EOF' >/etc/nginx/homeassistant.conf
        proxy_set_header Connection "upgrade";
EOF
include /etc/nginx/homeassistant.conf;
