I installed the last version HA 0.83.3. It’s failed every time I login from my computer and shows: “Unable to connect to Home Assistant.”. The log file shows:
2018-12-09 01:39:21 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.1763354704] Disconnected: Did not receive auth message within 10 seconds
2018-12-09 01:50:12 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.1763422768] Disconnected: Did not receive auth message within 10 seconds
2018-12-09 01:58:36 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.123.2
2018-12-09 02:03:00 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.123.49
and the service show:
01:39:01 mossbian hass[450]: 2018-12-09 01:39:01 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/token to 192.168.1.110 (auth: False)
01:39:01 mossbian hass[450]: 2018-12-09 01:39:01 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.110 (auth: False)
01:39:21 mossbian hass[450]: 2018-12-09 01:39:21 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.1763354704] Disconnected: Did not receive auth
01:40:24 mossbian hass[450]: 2018-12-09 01:40:24 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/providers to 192.168.123.2 (auth: False)
01:40:24 mossbian hass[450]: 2018-12-09 01:40:24 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/login_flow to 192.168.123.2 (auth: False)
01:49:51 mossbian hass[450]: 2018-12-09 01:49:51 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/login_flow/1bd7eab2673742f4a4f1168783a5039e to 192.168
01:49:52 mossbian hass[450]: 2018-12-09 01:49:52 INFO (MainThread) [homeassistant.components.http.view] Serving / to 192.168.123.2 (auth: False)
01:49:52 mossbian hass[450]: 2018-12-09 01:49:52 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/token to 192.168.123.2 (auth: False)
01:49:52 mossbian hass[450]: 2018-12-09 01:49:52 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.123.2 (auth: False)
01:50:12 mossbian hass[450]: 2018-12-09 01:50:12 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.1763422768] Disconnected: Did not receive auth
The same warning also appear when login from my other devices but all can login successed except my computer.
This problem appeared when I installed without change any file or config and I didn’t using DDNS. I tried add trust network and legacy API but doesn’t work.
I checked the port listening. After Switching Protocols the talking suddenly reset as
Clear cache and cookies on your computer for your home assistant and try again.
Changing the router because you can’t login to a local service is like changing the front door to your house because you can’t walk into the bathroom from the hallway
When you’re connected to the router on your internal Network it doesn’t go through a firewall on the router. It’s all on the same switch. Nothing is routed.
What extensions are running in your browser that could be blocking it?
I block all extensions on Chrome but still can’t login. I also tried Edge, not working.
When I trie IE its directly show "Unable to connect to Home Assistant. " without load the login page first.
I checked the auth file from \homeassistant.storage. It seems each time I try to login HA creates a new token under “refresh_tokens”. Is that normal?
If it’s actually logged me in, I don’t know why there’s still a auth timeout warning. Looks like the HA is waiting for the auth message from my computer. The auth message actually be sent, and HA received the message, show as in the auth file but still think it’s not until time out
That sound weird, but I totally have no ideal what happen and how to solve this…
I can’t help but want to look closely at that subnet of 123 unless it was set intentionally. Routers out of the box are almost always defaulted to .0, .1 or .100… never seen .123 used except in huge corporate LANs.
Im also getting this, I think its from my mobile phone because mostly its pointing to my firewalls internal ip. I can login though so I’m not sure why these messages are apperaing, I want them gone
I found that clicking on a esphome esp32 camera entity that is in a state of unavailable causes “Login attempt or request with invalid authentication from” in log file, not sure where to report that, I dont have any other unavailable entities atm, so I dont know if its a esphome issue or a core hass issue.
hello community
tried running an ESP32-cam with tasmota FW and it was ok, but the tasmota FW doesn’t have enough options to configure the cams quality
so I went for esp32-cam-webserver and get a stream quality with many options much better than with tasmota
I included the 2 cams like so in my configuration.yaml … minimal so to say
so far so good, stream is fine, but I always get these log warnings 2021-12-19 13:41:36 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from p200300e62f1c27009d1fb8809d612dac.dip0.t-ipconnect.de (2003:e6:2f1c:2700:9d1f:b880:9d61:2dac). (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.1.2 Safari/605.1.15)
this happens reproduceably like so
/dashboard/tab1 - picture glance on AUTO displaying the still image refreshed every 10 secs - click naviagte /dashboard/tab2
/dashboard/tab2 - picture glance on LIVE displaying the stream - click naviagte /dashboard/tab1
(1) I open browser homeassistant and load /dashboard/tab1
(2) naviagte to the stream by clicking o the pic glance still image (/dashboard/tab2), stream runs immediately
(3) back to /dashboard/tab1 and again forth to the stream /dashboard/tab2 like in (2)
(4) /dashboard/tab2 opens without the stream
(5) reload the browserpage on /dashboard/tab2 and the stream is back immediately but a warning is logged
