Login attempt or request with invalid authentication from: my public IP address
Hi All - I’m running HA in a docker container on my unraid server along with a cloudflare tunnel, nginx proxy manager and authentik for 2FA. I have a few other apps which work just fine but I cannot for the life of me get HA working.
The error I get in the logs is as follows:
WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from MY PUBLIC IP. Requested URL: ‘/auth/token’. (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36 Edg/106.0.1370.42)e[0m
I’ve followed the guide here
I am able to go to ha.mydomain.com and then authenticate via authentick but once I’m redirected to HA I get this page:
My config:
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.17.0.20
    - 172.17.0.1
auth_header:
    # Optionally set this if you're not using authentik proxy or oauth2_proxy
    username_header: X-authentik-username
    # Optionally enable debug mode to see the headers Home-Assistant gets
    # debug: false
# Optionally, if something is not working right, add this block below to get more information
logger:
    default: info
    logs:
        custom_components.auth_header: debug
Any help is greatly appreciated!
If you haven’t already got this working…
Try
172.17.0.20/24
I’m having the same issue. I tried expanding out trusted proxies all the way to 0.0.0.0/0 and it still didn’t work. Anyone have any ideas?
