I am getting the Login attempt or request with invalid autthentication from 192.168.1.254 which is my router. I have a Pace PLC 5268AC routher but have nothing in my config.yaml file that exposes the router address. I do have:
device_tracker:
- platform: bluetooth_tracker
set and:
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
base_url: https://budskiha.duckdns.org:8123
Secrets are defined in the file secrets.yaml
api_password: !secret http_password
set in by config.yaml file.
I just started to get the error message when I upgraded to 77.3 and supervisor 130.
Here are the error messages I get when I turn on DEBUG
2018-09-10 20:21:58 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.254 (auth: False)
2018-09-10 20:21:58 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1869151696: Connected
2018-09-10 20:21:58 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1869151696: Request auth
2018-09-10 20:21:58 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1869151696: Received api_password
2018-09-10 20:21:58 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1869151696: Authorization failed
2018-09-10 20:21:58 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.254
One difference is that my api-password is the password I use to sign-on to hassio and is also the password to my router. Because of the way my router is set up I also have a different password for wifi access. I tried to set the api-password to the wifi router password but then Nodered stopped talking to hassio.
Any ideas.
