I am doing the guides for the alexa integration but struggling right now:
Login attempt failed
Login attempt or request with invalid authentication from ec2-52-214-80-202.eu-west-1.compute.amazonaws.com (52.214.80.202). See the log for details.
This comes up when I test the AWS Lambda with the token I created for my user. Locally from the network via postman a basic API call is working with the same token.
I run HA behind a reverse proxy and think that the external (and continuously changing AWS) IPs are blocked. Did not found anything in the logs.
thanks for the help!
