Login intermittently hangs then fails
I’m encountering a strange login issue. Regardless of client device (PC, android, iphone) or connection (directly to HA server IP or through the reverse-proxy). Randomly when I open the app/website, it doesn’t log in, and instead hangs. Eventually it will show the retry prompt. About 80% of the time that will work, but sometimes it will still hang before the device eventually is able to get logged in. Additionally, if an app/browser has sat with HA open, it will eventually get disconnected and be unable to reconnect automatically for a long time.
Everytime I get this issue, I see a relatively unhelpful warning log: [device details] Disconnected: Did not receive auth message within 10 seconds. This issue started after I converted my HA setup from a docker instance running on a NAS into it’s own dedicated HAOS server. (By simply creating a backup of the configuration and importing that into the freshly installed HAOS server)
Has anyone else experienced this issue and may have some insight on what to look into next?
