I have a problem for a few days with the home assistant login page, it shows ** LOCATION ** ** NAME **.
I do not see where this problem comes from and how to fix it. I couldn’t find any info on that.
If anyone has a solution
Translations should be updated on Lokalise.
Ok, thanks for your answer but what should I do?
You should wait or correct translation yourself https://developers.home-assistant.io/docs/translations
An issue has been open (https://github.com/home-assistant/frontend/issues/8395) and closed
there was a problem with the translation (the French model on Lokalise) that was fixed a few days ago.
