Login screen
I have a Hass io setup on a RPI 3B+. The login screen is showing a message what i cannot relate to something.
Does anybody knows where i can find the cause of this error in my log files etc?
There is only one Home Assistant log file. You could start in the aptly named file homeassistant.log
I found what it was…:frowning:
DuckDNS is causing this problem
When i go to the login screen with the internal ip adress it works fine!
