I guess I forgot the password to the Phoscon WebApp (the web ui of the deCONZ) plugin.
But I cannot change the password and resetting it to the inital password does not help (or I am not sure what the inital password should be)
I tried resetting the password on my windows machine within the phoscon web app and there it works but on my Home-Assistant setup (running via hass.io on a RPi 3) I cannot login using any of my usual passwords, neither can I change the password.
I already uninstalled the deconz app, removed the deconz integration and re-installed it but it didn’t help.
Any Ideas how I could progress or debug this further?
did anyone get a solution for this? I can’t get into my deconz at all!
I am running hassio with deconz as add-on. how were you able to still access it via app?? thank you
I have the exact same problem, but I did not upadate anything, the auto-update button is set to off on my home assistant.
Suddenly today I cannot login my phoscon app withing home assistant. I tried password reset but with no luck, The green button “Set new password” doesn’t do anything.
