After one of recent updates (judging at last triggered date it was 2022.09) one of my automations stopped to work. Basically it just turns the light on in TV room when all devices are switched off by Harmony remote. Here is the automation code:
- alias: "Turn up lights on TV Power Off"
initial_state: true
platform: state
entity_id: sensor.tv_room_harmony_activity
to: 'PowerOff'
condition:
- condition: state
entity_id: light.tv_illumination
state: 'on'
- service: light.turn_on
entity_id:
- light.tv_illumination
- light.desk_lamp
- light.shelf_illumination
- light.tv_room_main
brightness: 100
transition: 3
entity_id:
- light.desk_lamp
brightness: 255
transition: 3
I think any issues with conditions can be disregarded, as this automation does not trigger at all - there is no trace of it being run and not being executed due to conditions in Debug automation. There is no trace of it being triggered at all… So it looks like trigger is failing. On the other hand I can see that state of this sensor changes to PowerOff so it should trigger… Also if it is changing from PowerOff (that is used in other automations) it triggers properly.
Here you can see sensor state changes:
And here Debug automation:
There is also no entry about this automation in the log… What might be the reason for trigger not working? How get this working again?
