spelling error
- type: entities
spelling error
- type: entities
The errors are saying unknown card type.
Look at your spacing, it appears as if your elements are at the card indentation level. See how elements says ‘null’? null means empty.
work with :
- type: entities
title: Harmony Hub
entities:
- switch.sfrtv
- switch.androidtv
but is not lovely lol
again 100000x thank you for your precious help !!!
I would have hoped to have a more beautiful graphic with images of funds and at least I can play on the sound but shame
at least I can turn on and turn off the tv
hello Petro,
New question now if i need send commande via protocol remote.send_command
could you help me please ?
Exemple remote.send_command for VolumeUp and VolumeDown for activity:51830162 (it’s the home cinema)
I have this in my scripts.yaml
### Living room volume up (Denon)
lr_volume_up:
alias: Volume Up
sequence:
- service: remote.send_command
entity_id: remote.YOUR_HARMONY
device: XXXXXXXX # Device ID number
command:
- VolumeUp
### Living room volume down (Denon)
lr_volume_down:
alias: Volume Down
sequence:
command:
- VolumeDown
### Living room volume mute (Denon)
lr_volume_mute:
alias: Volume Mute
sequence:
command:
- Mute
thank you i try your script :=)
Hi there,
I’m trying to implement template switches for my Harmony activities, but I’m having a bit of trouble. When I restarted HA after updating my config with the switches none of the new template switches appear as entities. I’m not getting any errors in the UI or the log about failure to setup switch.template or anything like that. Can anyone take a look at my config snippet and point me in the right direction? Note: I haven’t even tried to bring the switches into Lovelace, since the aren’t showing up as entities yet…
redacted template sensors here
#Harmony Activities
switches:
Sling TV:
value_template: "{{ is_state_attr('remote.harmony_hub', 'current_activity', 'Watch Sling TV') }}"
turn_on:
service: remote.turn_on
entity_id: remote.harmony_hub
activity: 'Watch Sling TV'
turn_off:
activity: 'PowerOff'
ESPN:
value_template: "{{ is_state_attr('remote.harmony_hub', 'current_activity', 'Watch ESPN') }}"
turn_on:
activity: 'Watch ESPN'
turn_off:
Baseball:
value_template: "{{ is_state_attr('remote.harmony_hub', 'current_activity', 'Watch Baseball') }}"
turn_on:
activity: 'Watch Baseball'
turn_off:
DVD:
value_template: "{{ is_state_attr('remote.harmony_hub', 'current_activity', 'Watch a DVD') }}"
turn_on:
activity: 'Watch a DVD'
turn_off:
Chromecast:
value_template: "{{ is_state_attr('remote.harmony_hub', 'current_activity', 'Watch Chromecast') }}"
turn_on:
activity: 'Watch Chromecast'
turn_off:
Thanks.
example:
first_indent:
second_indent:
third_indent:
fourth_indent: Each indent is 2 spaces in from the other indents.
Take a look at the fixed Sling TV switch and apply the changes to the others:
#Harmony Activities
switches:
sling_tv: #<--------------OBJECT_ID
friendly_name: Sling TV
turn_on:
turn_off:
Also, for further explanation:
switch.sling_tv # entity_id for your switch
\____/ \______/
domain |
object_id
