Dejan
(Dejan)
October 4, 2018, 9:57am
1
Dear all, i have decided to try the new interface LOVELACE UI and it’s beautifful, i have reconfigured all my items but failed for harmony hub and control tv ! i dont understand why i have try 24h some code… some exemple but nothing work !!! it’s really CRAZY !
Need help if anybody have successfully integrate Harmony hub and TV control to LOVELACE UI
I have view this tread in reddit guy have a super integration for logitech but dont work for me https://www.reddit.com/r/homeassistant/comments/9ceu4j/i_made_a_pictureelement_card_to_control_my_tv/
here my integration from configuration.yaml :
remote:
platform: harmony
host: 192.168.1.86
and my file harmony_harmony.conf :
Activities
31547838 - Regarder la TV
32707809 - Android Tv
-1 - PowerOff
Device Commands
53413622 - Lecteur multimédia Tanix
PowerToggle
Mute
VolumeDown
VolumeUp
DirectionDown
DirectionLeft
DirectionRight
DirectionUp
OK
Return
Menu
Home
Mouse
51830162 - Logitech Z-5500
PowerToggle
Mute
VolumeDown
VolumeUp
VolumeCenterDown
VolumeCenterUp
Settings
Effect
InputCoax
InputDirect
InputOptical
InputStereo1
InputStereo2
InputStereo3
SubWooferDown
SubWooferUp
SurroundDown
SurroundUp
Test
51830149 - Enregistreur numérique SFR
PowerToggle
0
1
2
3
4
5
6
7
8
9
Mute
VolumeDown
VolumeUp
ChannelPrev
ChannelDown
ChannelUp
DirectionDown
DirectionLeft
DirectionRight
DirectionUp
OK
Stop
Play
Rewind
Pause
FastForward
Record
Menu
Guide
Info
Exit
VOD
51830092 - TV LG
PowerOff
PowerOn
PowerToggle
0
1
2
3
4
5
6
7
8
9
Mute
VolumeDown
VolumeUp
ChannelPrev
ChannelDown
ChannelUp
DirectionDown
DirectionLeft
DirectionRight
DirectionUp
OK
Stop
Play
Rewind
Pause
FastForward
Record
Subtitle
Back
Teletext
Favorite
List
LiveTv
Green
Red
Blue
Yellow
Guide
Info
PageDown
PageUp
Exit
Aspect
Settings
3D
App/*
Input
InputAv1
InputAv2
InputComponent1
InputHdmi1
InputHdmi2
InputHdmi3
InputHdmi4
InputTv
MyApps
Q.Menu
SimpLink
Smart
T.Opt
Tv/Radio
and my file harmony_harmony_hub.conf :
Activities
31547838 - sfttv
32707809 - androidtv
-1 - PowerOff
Device Commands
PowerToggle
Mute
VolumeDown
VolumeUp
DirectionDown
DirectionLeft
DirectionRight
DirectionUp
OK
Return
Menu
Home
Mouse
PowerToggle
Mute
VolumeDown
VolumeUp
VolumeCenterDown
VolumeCenterUp
Settings
Effect
InputCoax
InputDirect
InputOptical
InputStereo1
InputStereo2
InputStereo3
SubWooferDown
SubWooferUp
SurroundDown
SurroundUp
Test
PowerToggle
0
1
2
3
4
5
6
7
8
9
Mute
VolumeDown
VolumeUp
ChannelPrev
ChannelDown
ChannelUp
DirectionDown
DirectionLeft
DirectionRight
DirectionUp
OK
Stop
Play
Rewind
Pause
FastForward
Record
Menu
Guide
Info
Exit
VOD
51830092 - TV LG
PowerOff
PowerOn
PowerToggle
0
1
2
3
4
5
6
7
8
9
Mute
VolumeDown
VolumeUp
ChannelPrev
ChannelDown
ChannelUp
DirectionDown
DirectionLeft
DirectionRight
DirectionUp
OK
Stop
Play
Rewind
Pause
FastForward
Record
Subtitle
Back
Teletext
Favorite
List
LiveTv
Green
Red
Blue
Yellow
Guide
Info
PageDown
PageUp
Exit
Aspect
Settings
3D
App/*
Input
InputAv1
InputAv2
InputComponent1
InputHdmi1
InputHdmi2
InputHdmi3
InputHdmi4
InputTv
MyApps
Q.Menu
SimpLink
Smart
T.Opt
Tv/Radio
thank you in advance for your time and your help
Dejan
petro
(Petro)
October 4, 2018, 12:16pm
2
Did you set up the switches in the last post you made? Without those, that guys method will not work in Lovelace.
petro
(Petro)
October 4, 2018, 12:20pm
3
Also, everything you posted in here will not lead anyone to properly configure lovelace. Everything you posted in here is related to harmony. You’ll need interface entitys in order to make lovelace work. This is configuration of harmony and it does not create anything in the interface.
Dejan
(Dejan)
October 4, 2018, 1:34pm
4
before testing Lovelace all harmony work, after testing lovelace nothing work… while with domoticz harmony setup work…
this is my current configuration in lovelace.yaml for front room :
Salon
icon: mdi:television
title: Salon
cards:
type: vertical-stack
cards:
type: picture-entity
title: Salon Camera
entity: camera.salon_2
camera-image: camera.salon_2
show_info: false
type: entities
entities:
type: entities
title: Yeelight
entities:
light.yeelight_color2_7c49ebb72dd2
type: picture
image: https://cdn.shopify.com/s/files/1/1547/6351/files/returns-2014.jpg
navigation_path: /lovelace/home/
i have sucessfully add yeelight and camera and wemo switch
but I do not know what to do for the harmony I would like to be able to control my activity and the volume like what could do the post on reedit
petro
(Petro)
October 4, 2018, 1:36pm
5
Did you add the switches mentioned in this post?
YYYYYYYYYEEEEEEEEEEEESSSSSSSSSSSSS
is gooooddd it’s just a space before “switch”
work fine nowwwwwwwwwwwww
thank you very very very very much
Dejan
(Dejan)
October 4, 2018, 1:39pm
6
add switch directly in lovelace.yaml ?
yes i have try
Dejan
(Dejan)
October 4, 2018, 1:43pm
7
and i got this error :
Lovelace
while parsing a block mapping in “/share/CACHEDEV1_DATA/.qpkg/Home-Assistant/CONFIG_DIR/ui-lovelace.yaml”, line 220, column 3 expected <block end>, but found ‘<block sequence start>’ in “/share/CACHEDEV1_DATA/.qpkg/Home-Assistant/CONFIG_DIR/ui-lovelace.yaml”, line 268, column 5
Dejan
(Dejan)
October 4, 2018, 1:44pm
8
Salon
title: Salon
cards:
cards:
title: Salon Camera
show_info: false
type: entities
entities:
type: entities
title: Yeelight
entities:
platform: template
switches:
sfrtv:
value_template: “{{ is_state_attr(‘remote.lgtv’, ‘current_activity’, ‘sfrtv’) }}”
turn_on:
service: remote.turn_on
entity_id: remote.lgtv
activity: ‘sfrtv’
turn_off:
activity: ‘PowerOff’
Android TV
androidtv:
value_template: “{{ is_state_attr(‘remote.lgtv’, ‘current_activity’, ‘androidtv’) }}”
turn_on:
activity: ‘androidtv’
turn_off:
type: picture
petro
(Petro)
October 4, 2018, 2:01pm
9
No, that’s not how this works.
Those switches need to be added in the template switch section of your normal configuration. They in turn will appear in your non-lovelace UI. Has this happened?
To me, it seems like you don’t have a fundamental understanding of how components and component sections work in home assistant and configuration.yaml. You will have a rough time if you don’t take the time to learn this.
EDIT:
Also, Please take the time to post code correctly. Right now you are just pasting your code into your comments without formatting them. Please read and follow the code posting practices covered in the blue ribbon at the top of the page.
Dejan
(Dejan)
October 4, 2018, 2:08pm
10
ok thank you i read and search but is not really simply
ps : i use home assistant in a QNAP device with directly QPKG i dont have hass.io and is very diffcule to access
petro
(Petro)
October 4, 2018, 2:10pm
11
It’s on the top of every post on every page inside this forum:
Dejan
(Dejan)
October 4, 2018, 2:11pm
12
SWITCHES.YAML
switches:
sfrtv:
value_template: "{{ is_state_attr('remote.lgtv', 'current_activity', 'sfrtv') }}"
turn_on:
activity: 'sfrtv'
turn_off:
activity: 'PowerOff'
# Android TV
androidtv:
value_template: "{{ is_state_attr('remote.lgtv', 'current_activity', 'androidtv') }}"
turn_on:
activity: 'androidtv'
turn_off:
Dejan
(Dejan)
October 4, 2018, 2:18pm
13
ui-lovelace.yaml
resources:
- url: /local/bignumber-card.js?v=0.0.1
type: js
- url: /local/monster-card.js?v=0.0.1
type: js
- url: /local/gauge-card.js?v=0.0.1
type: js
- url: /local/last-motion-card.js?v=0.0.1
type: js
- url: /local/card-tracker.js?v=0.0.1
type: js
- url: /local/useful-markdown-card.js?v=0.0.1
type: js
# Accueil #
- icon: mdi:home
title: Accueil
cards:
# - type: picture-elements
# image: /local/hatheme3.jpg
# elements:
# - type: state-label
# entity: sensor.time
# style:
# top: 8%
# left: 10%
# color: rgb(249, 251, 255)
# text-shadow: 2px 2px DarkSlateGrey
# font-family: Trebuchet MS
# font-weight: bold
# pointer-events: none
# text-rendering: optimizeLegibility
# -moz-osx-font-smoothing: grayscale
# font-smoothing: antialiased
# -webkit-font-smoothing: antialiased
# - type: state-icon
# entity: sensor.outside_temp
# style:
# top: 7.8%
# left: 80%
# max-width: 24px
# max-height: 24px
# style:
# top: 8%
# left: 90%
# font-weight: bold
# entity: sensor.time_of_day
# style:
# top: 40%
# left: 50%
# font-size: 200%
# font-style: oblique
# font-weight: 400
# entity: sensor.outside_alerts
# style:
# top: 52%
# left: 50%
# font-size: 120%
# font-weight: 400
- type: picture-glance
title: Garage
image:
camera_image: camera.garage
entities:
- camera.garage
- camera.enable_motion_detection
- light.garden_light
- binary_sensor.front_door
title: Veranda
image:
navigation_path: /lovelace/kitchen
camera_image: camera.veranda
entities:
- camera.veranda
- binary_sensor.motion_kitchen
- input_select.dishwasher_status
- climate.kitchen
title: Salle
image:
navigation_path: /lovelace/living_room
camera_image: camera.salon
entities:
- camera.salon
- binary_sensor.motion_living_room
- group.living_room_lights
- switch.living_room_scentsy_relay
title: Salon
image:
navigation_path: /lovelace/front_room
camera_image: camera.salon_2
entities:
- camera.salon_2
- binary_sensor.motion_front_room
- light.front_room_main_light
image: https://home-assistant-lovelace-gallery.netlify.com/images/living_room.png
title: Salon
entities:
- binary_sensor.motion_bedroom
- switch.power_bedroom_humidifier
- switch.scentsy_bedroom
- light.bedroom_main_light
image: https://www.meubis.be/files/cache/small/files/lester-20sfeer-58ad86b1c1e87.JPG
title: Salle
entities:
image: https://home-assistant-lovelace-gallery.netlify.com/images/kitchen.png
title: Cuisine
entities:
image: https://images2.roomstogo.com/is/image/roomstogo/br_rm_belmar_black_pan~Belmar-Black-5-Pc-Queen-Bedroom.jpeg
title: Chambre
navigation_path: /lovelace/bedroom
entities:
# "zones"
# outdoor
# kitchen
# living Room
# front Room
# bedroom
# spare Room
# Circulation areas
- type: glance
title: Lumière Maison
entities:
- entity: light.yeelight_color2_7c49ebb72dd2
- entity: light.yeelight_color2_7c49ebb7ff82
- entity: light.yeelight_color2_7c49ebb73a90
# Salon #
- icon: mdi:television
title: Salon
cards:
- type: vertical-stack
cards:
- type: picture-entity
title: Salon Camera
show_info: false
- type: entities
entities:
- switch.wemo_switch
- type: entities
title: Yeelight
entities:
- light.yeelight_color2_7c49ebb72dd2
- type: picture
petro
(Petro)
October 4, 2018, 2:33pm
14
So you are very close, The guy in that post uses picture-elements to make that nice remote. He then uses icon elements using template switches:
image: /local/someimage.jpg
elements:
- type: icon
icon: mdi:android
tap_action: toggle
entity: switch.androidtv
style:
top: 10%
left: 10%
- type: icon
tap_action: toggle
entity: switch.lgtv
style:
top: 10%
left: 90%
You’ll have to play around with the style positions and add the image you want.
Dejan
(Dejan)
October 4, 2018, 2:48pm
15
so i have add code.
I have uploaded all image in www/icons/media_icons/
add code in my ui-lovelace.yaml
image: /local/icons/media_icons/LHarmonyBG.jpg
elements:
- type: icon
icon: mdi:android
tap_action: toggle
style:
top: 10%
left: 10%
- type: icon
tap_action: toggle
entity: switch.lgtv
style:
top: 10%
left: 90%
Lovelace
while parsing a block collection in “/share/CACHEDEV1_DATA/.qpkg/Home-Assistant/CONFIG_DIR/ui-lovelace.yaml”, line 224, column 5 expected <block end>, but found ‘?’ in “/share/CACHEDEV1_DATA/.qpkg/Home-Assistant/CONFIG_DIR/ui-lovelace.yaml”, line 240, column 5
line 224 is :
line 240 is :
petro
(Petro)
October 4, 2018, 3:46pm
16
Do you have a file in that location?
When you specifiy /local/, that is refering to config/www directory.
So your folder structure should have a www folder inside the config folder.
david1
(David)
October 4, 2018, 4:30pm
17
Quick question, if you enable the home assistant skill in alexa, can you use alexa to turn off these “switches”
petro
(Petro)
October 4, 2018, 4:59pm
18
Yes, template switches act like a hardware switch:
This is my configuration for Harmony template switches (and a few others):
switches:
# ZONE 1 MEDIA SWITCH
zone_1:
value_template: "{{ is_state('media_player.yamaha_receiver', 'on') }}"
turn_on:
service: media_player.turn_on
entity_id: media_player.yamaha_receiver
turn_off:
service: media_player.turn_off
# ZONE 2 MEDIA SWITCH
zone_2:
value_template: "{{ is_state('media_player.yamaha_receiver_zone_2', 'on') }}"
turn_on:
entity_id: media_player.yamaha_receiver_zone_2
turn_off:
# XBOX HARMONY ACTIVITY
xbox_one:
value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Xbox One') }}"
turn_on:
entity_id: remote.living_room
activity: 'Xbox One'
turn_off:
# PLAYSTATION HARMONY ACTIVITY
ps4:
value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'PS4') }}"
turn_on:
activity: 'PS4'
turn_off:
# WII U HARMONY ACTIVITY
wii_u:
value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Wii U') }}"
turn_on:
activity: 'Wii U'
turn_off:
# PC HARMONY ACTIVITY
pc:
value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'PC') }}"
turn_on:
activity: 'PC'
turn_off:
# SWITCH HARMONY ACTIVITY
switch:
value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Switch') }}"
turn_on:
activity: 'Switch'
turn_off:
# TV HARMONY ACTIVITY
tv:
value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'TV') }}"
turn_on:
activity: 'TV'
turn_off:
# AUDIO 1, USED FOR ECHO AND MUSIC ZONE 1
audio_1:
value_template: "{{ is_state_attr('media_player.yamaha_receiver', 'source', 'Echo') and is_state('switch.floating_outlet_switch', 'on') }}"
turn_on:
- service: switch.turn_on
entity_id: switch.floating_outlet_switch
- service: media_player.turn_on
- service: media_player.select_source
source: Echo
- service: media_player.volume_set
volume_level: 0.7
turn_off:
- service: switch.turn_off
- service: media_player.turn_off
# AUDIO 2, USED FOR ECHO AND MUSIC ZONE 2
audio_2:
value_template: "{{ is_state_attr('media_player.yamaha_receiver_zone_2', 'source', 'Echo') and is_state('switch.floating_outlet_switch', 'on') }}"
turn_on:
source: Echo
volume_level: 0.7
turn_off:
And in lovelace, I use a conditional card with a picture-glance card and a few entity cards. Here’s that config:
title: Entertainment
cards:
cards:
title: Harmony
entities:
- switch.xbox_one
- switch.ps4
- switch.wii_u
- switch.pc
- switch.switch
- switch.tv
state_image:
"PowerOff": /local/images/power_off.png
"Xbox One": /local/images/xbox_one_logo.png
"PS4": /local/images/playstation_logo.png
"Wii U": /local/images/wiiu_logo.png
"PC": /local/images/windows_logo.png
"Switch": /local/images/nintendo_switch_logo.png
"TV": /local/images/sony_logo.png
entity: sensor.harmony_activity
- type: entity-filter
entities:
- sensor.redacted
- sensor.xbox_current
state_filter:
- 'Online'
- 'Home'
- 'Netflix'
show_empty: false
cards:
title: Yamaha Receiver
entities:
- switch.zone_1
- switch.audio_1
- switch.zone_2
- switch.audio_2
image: /local/images/rxv677.png
- type: conditional
conditions:
- entity: switch.zone_1
state: 'on'
- entity: switch.zone_2
state: 'on'
card:
type: entities
entities:
- entity: input_number.yamaha_receiver
name: Zone 1 Volume
- entity: input_number.yamaha_receiver_zone_2
name: Zone 2 Volume
- type: conditional
conditions:
state: 'on'
state: 'off'
card:
type: entities
entities:
- type: conditional
conditions:
state: 'off'
state: 'on'
card:
type: entities
entities:
And this is what it ends up looking like:
Powered Off
Xbox On
PlayStation On & Receiver Zone 2 On
Dejan
(Dejan)
October 4, 2018, 5:42pm
19
some resultat with www
image: /local/www/icons/media_icons/LHarmonyBG.jpg
Lovelace
ps: i love your interface for power switch
after i have try just
- type: entitites
title: Harmony
entities:
- switch.androidtv
- switch.lgtv
interface work but this part dont work i have card error in HA :
petro
(Petro)
October 4, 2018, 6:00pm
20
Your folder structure has the www, not the path you write in the image.
For example:
file location in home assistant OS:
config/www/icons/media_icons/LHarmonyBG.jpg
then your yaml would location would be:
