I have some Logitech Pop buttons I purchased before going all-in with Home Assistant. I would like to use them to control some Sonoff switches.
I can add the Sonoff switches to the Pop app successfully (using Emulated Hue), but whenever I try to use them I get errors that they’ve lost the connection with the hub.
Has anyone gotten this to work? I’d prefer to avoid IFTTT because of latency and the tendency for the lights’ on/off status to fall out of sync with each other.
I didn’t get it to work at the time and have been using IFTTT since. I never tried again, but it’d be great if something changed in the last few months. Did you try what I did and get the same errors?
No, I was trying to decide if I wanted to buy some Pop buttons, but it sounds like I should just stick with the Amazon Dash buttons for now. So far, Dasher seems to be very consistent even though it was a bit of a pain to install and configure.
I was able to recently get this working so I thought I’d share my results.
Basically, I’m using emulated hue -> harmony home hub -> logitech pop. I was unable to add the emulated hue directly to the logitech pop app (it stops at the “press the button on your hue to continue” prompt and there doesn’t appear to be a mechanism to simulate an emulated hue button press via home assistant). However, I could add the emulated hue to the harmony home hub. It also prompts for a physical button press on the hue but it will accept the button as “pushed” after about ~30 seconds or so (not sure why, but it’s great that it works).
Once the emulated hue was picked up by the harmony hub, I could access my home assistant scripts from within the harmony hub app. This carried over to the logitech pop app after I connected the logitech pop app to the harmony hub.
It’s a little convoluted to go from home assistant --> emulated hue --> harmony home hub --> logitech pop, but it does work very well! Very little lag time and no need for IFTTT.
For those who might still be interested in getting emulated hue working with the logitech pop, I just thought I’d mention that I manage to get it working with a bit of extra code after leveraging what was found here (credit to them).
I, too, would like some help here. I have Home Assistant setup with emulated_hue running. When I try to connect using the Logitech POP app (on android), I get the message saying “To pair your Phillips Hue, press the button in the centre of the Hub”. Obviously, I don’t have any button to press and nothing I do can get me past this screen. With ha-bridge, there was a pop-up on the web page to simulate a button press.
Is your emulated_hue listening on port 80? When the ‘press button’ request comes up, mine just disappears a second later (as if a button was pressed). I’m on iOS, so I don’t know if any of this helps. This is what I have on my config:
i order a Logitech Pop button (without the logitech pop hub). is it possible to pair this with the philipe hue hub (physical) ?
i use the HA on a VMWare ESXi Server - not on a raspi
