I would like to see the logout button as a main menu item, just above/below the user.
I had also faced to the same problem and got one solution from ChatGPT.
Create a button that send to the url
http://[your home assistant ip:port]/auth/authorize?response_type=code&client_id=[your home assistant ip:port]/&redirect_uri=[your home assistant ip:port]
It’s working fine in my loveleace.
