Hey all,
Background: I’ve successfully set up automation with my rbPi 3 using the old all-in-one installer. I’m now trying to get everything running using the HASSbian image.
I’ve successfully installed HASSbian on my raspberry pi 3. I can access the web ui without a problem, etc. However, I am unable to view any HASS logs… when I try to view the logs in the UI (or by using Postman or Paw), I get this error:
http://MY_RBPI_IP_ADDR:8123/api/error_log 404 NOT FOUND
I’ve confirmed the password and everything is being sent to my pi, and all other commands seem to work just fine.
I’ve also been able to use FileZilla to edit the configuration.yaml
file and I’m trying to add all my Open Zwave configs back in… I’ve installed all the open zwave stuff afaik but I can’t debug because the logs don’t show up. Anyone know why this might be?
I’m using Home Assistant 0.30.1.
