<!-- READ THIS FIRST:
- Make sure you run the latest version of the Android app…
- Make sure you run the latest version of Home Assistant
- Make sure to check the Companion docs for troubleshooting and configuration: https://companion.home-assistant.io/
- Make sure the bug you found is not already reported, we love to put work in bugfixes instead of closing duplicate bug reports
DO NOT DELETE ANY TEXT from this template! All requested information is important.
**Home Assistant Android version:**
HA companion app for android 2021.10 minmal version
**Android version:**
Android 8.1 without GMS (no playstore, and you can't install it neither or change the rom)
**Phone model:**
https://iiyama.com/nl_nl/products/prolite-tw1523as-b1p/
It's a POE Android Touchscreen brand new. Without lithium battery so it's safe to run 24/7 on the wall.
**Home Assistant version:**
2021.12.3
**Last working Home Assistant release (if known):**
2021.10
**Description of problem:**
Companion app only want to start once. And after installation it won't start. It says "Unable to connect to Home Assistant"
hitting refresh doesn't work (anymore). The url is correct, it also works on my other devices the inhouse so it ain't my HA install.
![image0](https://user-images.githubusercontent.com/76201374/146821101-78263abf-a855-4979-bc4b-154a2ff2c2f1.jpeg)
**Traceback (if applicable, to get the logs you may refer to: https://companion.home-assistant.io/docs/troubleshooting/faqs/#android-crash-logs):**
--------- beginning of main
12-20 10:56:58.994 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 10:56:59.585 2770 2792 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 10:56:59.671 2770 2786 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 10:56:59.677 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 11:11:28.720 2770 2781 I zygote : Background concurrent copying GC freed 399964(9MB) AllocSpace objects, 0(0B) LOS objects, 50% free, 8MB/17MB, paused 628us total 128.223ms
12-20 11:11:38.255 2770 2770 D UrlRepository: Using external URL
12-20 11:11:38.281 2770 1358 W libEGL : EGLNativeWindowType 0x85125808 disconnect failed
12-20 11:11:38.300 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 11:11:38.300 2770 2770 D UrlRepository: Using external URL
12-20 11:11:38.319 2770 2770 I chromium: [INFO:CONSOLE(1)] "The key "viewport-fit" is not recognized and ignored.", source: http://192.168.66.66:8123/ (1)
12-20 11:11:38.322 2770 2770 I chromium: [INFO:CONSOLE(1)] "Uncaught SyntaxError: Unexpected token import", source: http://192.168.66.66:8123/ (1)
12-20 11:11:38.417 2770 2770 I chromium: [INFO:CONSOLE(2)] "Uncaught ReferenceError: regeneratorRuntime is not defined", source: http://192.168.66.66:8123/frontend_es5/app.dc5acec3.js (2)
12-20 11:11:39.259 2770 2694 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 11:11:39.259 2770 2694 D UrlRepository: Using external URL
12-20 11:11:48.273 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 11:11:48.321 2770 1358 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
12-20 11:11:59.724 2770 1809 D SensorWorker: Updating all Sensors.
12-20 11:11:59.729 2770 2786 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 11:11:59.741 2770 1809 D LastUpdate: Last update is SensorWorker
12-20 11:11:59.744 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 11:12:00.171 2770 1809 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 11:12:00.238 2770 2812 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 11:12:00.259 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 11:18:54.427 2770 2781 I zygote : Background concurrent copying GC freed 319501(8MB) AllocSpace objects, 2(104KB) LOS objects, 49% free, 9MB/18MB, paused 922us total 122.590ms
12-20 11:27:00.287 2770 1809 D SensorWorker: Updating all Sensors.
12-20 11:27:00.291 2770 2812 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 11:27:00.302 2770 1809 D LastUpdate: Last update is SensorWorker
12-20 11:27:00.307 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 11:27:01.020 2770 1809 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 11:27:01.091 2770 2795 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 11:27:01.104 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 11:27:04.080 2770 2781 I zygote : Background concurrent copying GC freed 358467(8MB) AllocSpace objects, 0(0B) LOS objects, 49% free, 9MB/18MB, paused 641us total 120.055ms
12-20 11:37:10.503 2770 2781 I zygote : Background concurrent copying GC freed 403389(9MB) AllocSpace objects, 0(0B) LOS objects, 49% free, 8MB/17MB, paused 732us total 104.962ms
12-20 11:42:01.182 2770 1809 D SensorWorker: Updating all Sensors.
12-20 11:42:01.190 2770 2786 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 11:42:01.209 2770 1809 D LastUpdate: Last update is SensorWorker
12-20 11:42:01.220 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 11:42:01.936 2770 1809 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 11:42:02.022 2770 2812 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 11:42:02.029 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 11:57:02.114 2770 1809 D SensorWorker: Updating all Sensors.
12-20 11:57:02.122 2770 2812 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 11:57:02.137 2770 1809 D LastUpdate: Last update is SensorWorker
12-20 11:57:02.143 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 11:57:02.629 2770 1809 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 11:57:02.691 2770 2786 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 11:57:02.711 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 12:03:15.582 2770 2781 I zygote : Background concurrent copying GC freed 350208(8MB) AllocSpace objects, 0(0B) LOS objects, 49% free, 8MB/17MB, paused 378us total 118.427ms
12-20 12:12:02.714 2770 1809 D SensorWorker: Updating all Sensors.
12-20 12:12:02.717 2770 2786 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 12:12:02.725 2770 1809 D LastUpdate: Last update is SensorWorker
12-20 12:12:02.737 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 12:12:03.202 2770 1809 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 12:12:03.283 2770 2795 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 12:12:03.294 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 12:12:03.312 2770 2781 I zygote : Background concurrent copying GC freed 362772(8MB) AllocSpace objects, 0(0B) LOS objects, 49% free, 9MB/19MB, paused 145us total 101.988ms
12-20 12:27:03.317 2770 1809 D SensorWorker: Updating all Sensors.
12-20 12:27:03.319 2770 2795 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 12:27:03.324 2770 1809 D LastUpdate: Last update is SensorWorker
12-20 12:27:03.341 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 12:27:03.792 2770 1809 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 12:27:03.843 2770 2812 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 12:27:03.857 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 12:30:37.173 2770 2781 I zygote : Background concurrent copying GC freed 345669(8MB) AllocSpace objects, 0(0B) LOS objects, 49% free, 8MB/17MB, paused 368us total 114.622ms
12-20 12:42:03.919 2770 2308 D SensorWorker: Updating all Sensors.
12-20 12:42:03.921 2770 2795 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 12:42:03.933 2770 2308 D LastUpdate: Last update is SensorWorker
12-20 12:42:03.942 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 12:42:04.397 2770 2308 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 12:42:04.494 2770 2786 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 12:42:04.501 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 12:48:27.102 2770 2781 I zygote : Background concurrent copying GC freed 347422(8MB) AllocSpace objects, 0(0B) LOS objects, 50% free, 8MB/17MB, paused 408us total 122.215ms
12-20 12:57:04.547 2770 2308 D SensorWorker: Updating all Sensors.
12-20 12:57:04.552 2770 2795 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 12:57:04.564 2770 2308 D LastUpdate: Last update is SensorWorker
12-20 12:57:04.570 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 12:57:05.255 2770 2308 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 12:57:05.353 2770 2786 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 12:57:05.369 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 12:57:05.369 2770 2781 I zygote : Background concurrent copying GC freed 366126(8MB) AllocSpace objects, 0(0B) LOS objects, 50% free, 9MB/19MB, paused 156us total 111.060ms
12-20 13:07:34.259 2770 2781 I zygote : Background concurrent copying GC freed 438071(10MB) AllocSpace objects, 0(0B) LOS objects, 50% free, 8MB/17MB, paused 93us total 100.036ms
12-20 13:12:05.412 2770 2308 D SensorWorker: Updating all Sensors.
12-20 13:12:05.416 2770 2786 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 13:12:05.429 2770 2308 D LastUpdate: Last update is SensorWorker
12-20 13:12:05.431 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 13:12:05.839 2770 2308 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 13:12:05.898 2770 2812 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 13:12:05.907 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 13:25:01.887 2770 2781 I zygote : Background concurrent copying GC freed 390542(9MB) AllocSpace objects, 0(0B) LOS objects, 50% free, 8MB/17MB, paused 424us total 118.022ms
12-20 13:27:05.958 2770 2308 D SensorWorker: Updating all Sensors.
12-20 13:27:05.963 2770 2812 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 13:27:05.974 2770 2308 D LastUpdate: Last update is SensorWorker
12-20 13:27:05.995 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 13:27:06.429 2770 2308 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 13:27:06.495 2770 2795 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 13:27:06.511 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 13:32:50.763 2770 2781 I zygote : Background concurrent copying GC freed 349536(8MB) AllocSpace objects, 0(0B) LOS objects, 50% free, 8MB/17MB, paused 622us total 109.779ms
12-20 13:42:06.572 2770 2792 D SensorWorker: Updating all Sensors.
12-20 13:42:06.574 2770 2812 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 13:42:06.579 2770 2792 D LastUpdate: Last update is SensorWorker
12-20 13:42:06.594 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 13:42:06.903 2770 2781 I zygote : Background concurrent copying GC freed 373947(8MB) AllocSpace objects, 0(0B) LOS objects, 49% free, 9MB/18MB, paused 120us total 103.623ms
12-20 13:42:06.999 2770 2792 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 13:42:07.051 2770 2795 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 13:42:07.072 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 13:45:00.166 2770 2770 D UrlRepository: Using external URL
12-20 13:45:00.173 2770 1358 W libEGL : EGLNativeWindowType 0x85e1e808 disconnect failed
12-20 13:45:00.173 2770 1358 D OpenGLRenderer: endAllActiveAnimators on 0x7f69d580 (RippleDrawable) with handle 0x8793c0b0
12-20 13:45:00.193 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 13:45:00.193 2770 2770 D UrlRepository: Using external URL
12-20 13:45:00.240 2770 2770 I chromium: [INFO:CONSOLE(1)] "The key "viewport-fit" is not recognized and ignored.", source: http://192.168.66.66:8123/ (1)
12-20 13:45:00.250 2770 2770 I chromium: [INFO:CONSOLE(1)] "Uncaught SyntaxError: Unexpected token import", source: http://192.168.66.66:8123/ (1)
12-20 13:45:00.331 2770 2770 I chromium: [INFO:CONSOLE(2)] "Uncaught ReferenceError: regeneratorRuntime is not defined", source: http://192.168.66.66:8123/frontend_es5/app.dc5acec3.js (2)
12-20 13:45:01.168 2770 2953 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 13:45:01.168 2770 2953 D UrlRepository: Using external URL
12-20 13:45:10.203 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 13:45:10.273 2770 1358 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
12-20 13:57:07.111 2770 2792 D SensorWorker: Updating all Sensors.
12-20 13:57:07.116 2770 2786 I WM-Processor: Moving WorkSpec (8e4ff366-08ef-4983-acb2-aa6b6aa748af) to the foreground
12-20 13:57:07.129 2770 2792 D LastUpdate: Last update is SensorWorker
12-20 13:57:07.142 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 13:57:07.824 2770 2792 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 13:57:07.889 2770 2795 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=8e4ff366-08ef-4983-acb2-aa6b6aa748af, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 13:57:07.897 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 13:57:10.890 2770 2770 D UrlRepository: Using external URL
12-20 13:57:10.918 2770 1358 W libEGL : EGLNativeWindowType 0x85125808 disconnect failed
12-20 13:57:10.937 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 13:57:10.937 2770 2770 D UrlRepository: Using external URL
12-20 13:57:10.957 2770 2770 I chromium: [INFO:CONSOLE(1)] "The key "viewport-fit" is not recognized and ignored.", source: http://192.168.66.66:8123/ (1)
12-20 13:57:10.962 2770 2770 I chromium: [INFO:CONSOLE(1)] "Uncaught SyntaxError: Unexpected token import", source: http://192.168.66.66:8123/ (1)
12-20 13:57:10.963 2770 2770 I chromium: [INFO:CONSOLE(1)] "Uncaught SyntaxError: Unexpected token import", source: http://192.168.66.66:8123/ (1)
12-20 13:57:11.059 2770 2770 I chromium: [INFO:CONSOLE(2)] "Uncaught ReferenceError: regeneratorRuntime is not defined", source: http://192.168.66.66:8123/frontend_es5/app.dc5acec3.js (2)
12-20 13:57:17.808 2770 2792 D SensorWorker: Updating all Sensors.
12-20 13:57:17.820 2770 2812 I WM-Processor: Moving WorkSpec (927630f9-f45a-4fe3-b643-94790ea8ba5c) to the foreground
12-20 13:57:17.879 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 13:57:17.895 2770 2792 D LastUpdate: Last update is SensorWorker
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: Work [ id=927630f9-f45a-4fe3-b643-94790ea8ba5c, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ] was cancelled
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: java.util.concurrent.CancellationException: Task was cancelled.
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.cancellationExceptionWithCause(AbstractFuture.java:1184)
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.getDoneValue(AbstractFuture.java:514)
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.get(AbstractFuture.java:475)
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.WorkerWrapper$2.run(WorkerWrapper.java:300)
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.SerialExecutor$Task.run(SerialExecutor.java:91)
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
12-20 13:57:18.929 2770 2786 I WM-WorkerWrapper: at java.lang.Thread.run(Thread.java:764)
12-20 13:57:19.013 2770 2781 I zygote : Background concurrent copying GC freed 353521(8MB) AllocSpace objects, 0(0B) LOS objects, 49% free, 9MB/19MB, paused 820us total 630.001ms
12-20 13:57:19.095 2770 2812 E WM-WorkerWrapper: Didn't find WorkSpec for id 927630f9-f45a-4fe3-b643-94790ea8ba5c
12-20 13:57:19.664 2770 2770 D LastUpdate: Last update is android.intent.action.SCREEN_OFF
12-20 13:57:19.718 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 13:57:19.773 2770 2770 I WM-SystemFgService: Re-initializing SystemForegroundService after a request to shut-down.
12-20 13:57:19.774 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 13:57:19.791 2770 2770 I WM-SystemFgService: Re-initializing SystemForegroundService after a request to shut-down.
12-20 13:57:19.792 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 13:57:19.812 2770 1809 D SensorWorker: Updating all Sensors.
12-20 13:57:19.839 2770 2812 I WM-Processor: Moving WorkSpec (186632c0-a92d-4ba1-a161-8180fea9b718) to the foreground
12-20 13:57:19.918 2770 1809 D LastUpdate: Last update is SensorWorker
12-20 13:57:20.002 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 13:57:21.379 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 13:57:21.430 2770 2770 I WM-SystemFgService: Re-initializing SystemForegroundService after a request to shut-down.
12-20 13:57:21.431 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 20:16:23.123 2770 2770 W zygote : Long monitor contention with owner arch_disk_io_1 (2797) at void android.database.sqlite.SQLiteConnectionPool.releaseConnection(android.database.sqlite.SQLiteConnection)(SQLiteConnectionPool.java:391) waiters=0 in android.database.sqlite.SQLiteConnection android.database.sqlite.SQLiteConnectionPool.waitForConnection(java.lang.String, int, android.os.CancellationSignal) for 1.962s
12-20 20:16:23.363 2770 2770 D LastUpdate: Last update is android.intent.action.SCREEN_ON
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: Work [ id=186632c0-a92d-4ba1-a161-8180fea9b718, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ] was cancelled
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: java.util.concurrent.CancellationException: Task was cancelled.
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.cancellationExceptionWithCause(AbstractFuture.java:1184)
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.getDoneValue(AbstractFuture.java:514)
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.get(AbstractFuture.java:475)
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.WorkerWrapper$2.run(WorkerWrapper.java:300)
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.SerialExecutor$Task.run(SerialExecutor.java:91)
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
12-20 20:16:23.484 2770 2786 I WM-WorkerWrapper: at java.lang.Thread.run(Thread.java:764)
12-20 20:16:23.500 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 20:16:23.510 2770 2770 D ButtonWidget: Broadcast received:
12-20 20:16:23.510 2770 2770 D ButtonWidget: Broadcast action: android.intent.action.SCREEN_ON
12-20 20:16:23.510 2770 2770 D ButtonWidget: AppWidgetId: -1
12-20 20:16:23.511 2770 2770 D ButtonWidget: Updating all widgets
12-20 20:16:23.528 2770 2770 D StaticWidget: Broadcast received:
12-20 20:16:23.528 2770 2770 D StaticWidget: Broadcast action: android.intent.action.SCREEN_ON
12-20 20:16:23.528 2770 2770 D StaticWidget: AppWidgetId: -1
12-20 20:16:23.530 2770 2770 D StaticWidget: Updating all widgets
12-20 20:16:23.534 2770 2812 E WM-WorkerWrapper: Didn't find WorkSpec for id 186632c0-a92d-4ba1-a161-8180fea9b718
12-20 20:16:23.543 2770 2770 D MediaPlayCtrlsWidget: Broadcast received:
12-20 20:16:23.543 2770 2770 D MediaPlayCtrlsWidget: Broadcast action: android.intent.action.SCREEN_ON
12-20 20:16:23.543 2770 2770 D MediaPlayCtrlsWidget: AppWidgetId: -1
12-20 20:16:23.545 2770 2770 D MediaPlayCtrlsWidget: Updating all widgets
12-20 20:16:23.560 2770 2770 D TemplateWidget: Broadcast received:
12-20 20:16:23.560 2770 2770 D TemplateWidget: Broadcast action: android.intent.action.SCREEN_ON
12-20 20:16:23.560 2770 2770 D TemplateWidget: AppWidgetId: -1
12-20 20:16:23.561 2770 2770 D TemplateWidget: Updating all widgets
12-20 20:16:23.587 2770 2795 E WM-WorkerWrapper: Didn't find WorkSpec for id a91c05eb-83c9-483b-8347-d1b3afd8f426
12-20 20:16:23.596 2770 2213 D SensorWorker: Updating all Sensors.
12-20 20:16:23.598 2770 2795 I WM-Processor: Moving WorkSpec (519a5c7a-5df3-4180-a37c-d37bb65590f0) to the foreground
12-20 20:16:23.603 2770 3029 D LastUpdate: Last update is SensorWorker
12-20 20:16:23.616 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 20:16:24.315 2770 3031 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:24.315 2770 3031 D UrlRepository: Using external URL
12-20 20:16:24.319 2770 2770 I chromium: [INFO:CONSOLE(2)] "WebSocket connection to 'ws://192.168.66.66:8123/api/websocket' failed: Error in connection establishment: net::ERR_ADDRESS_UNREACHABLE", source: http://192.168.66.66:8123/frontend_es5/core.82323f4c.js (2)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: Unable to retrieve external auth
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: java.net.ConnectException: Failed to connect to /192.168.66.66:8123
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:297)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connect(RealConnection.kt:207)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.kt:226)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.kt:106)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.kt:74)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall.initExchange$okhttp(RealCall.kt:255)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:32)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at io.homeassistant.companion.android.common.data.HomeAssistantRetrofit$special$$inlined$-addInterceptor$1.intercept(OkHttpClient.kt:1087)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:517)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at java.lang.Thread.run(Thread.java:764)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: Caused by: java.net.ConnectException: failed to connect to /192.168.66.66 (port 8123) from /:: (port 0) after 10000ms: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connect(IoBridge.java:138)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:129)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:356)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:357)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at java.net.Socket.connect(Socket.java:616)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.platform.AndroidPlatform.connectSocket(AndroidPlatform.kt:63)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:295)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: ... 20 more
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: Caused by: android.system.ErrnoException: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at libcore.io.Linux.connect(Native Method)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at libcore.io.BlockGuardOs.connect(BlockGuardOs.java:126)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connectErrno(IoBridge.java:169)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connect(IoBridge.java:130)
12-20 20:16:24.336 2770 2770 E WebViewPresenterImpl: ... 28 more
12-20 20:16:24.337 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:24.337 2770 2770 D UrlRepository: Using external URL
12-20 20:16:24.341 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:24.405 2770 1358 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: Work [ id=519a5c7a-5df3-4180-a37c-d37bb65590f0, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ] was cancelled
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: java.util.concurrent.CancellationException: Task was cancelled.
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.cancellationExceptionWithCause(AbstractFuture.java:1184)
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.getDoneValue(AbstractFuture.java:514)
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.get(AbstractFuture.java:475)
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.WorkerWrapper$2.run(WorkerWrapper.java:300)
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: at androidx.work.impl.utils.SerialExecutor$Task.run(SerialExecutor.java:91)
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
12-20 20:16:24.420 2770 2786 I WM-WorkerWrapper: at java.lang.Thread.run(Thread.java:764)
12-20 20:16:24.456 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 20:16:24.501 2770 2770 I WM-SystemFgService: Re-initializing SystemForegroundService after a request to shut-down.
12-20 20:16:24.501 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 20:16:25.342 2770 3031 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:25.342 2770 3031 D UrlRepository: Using external URL
12-20 20:16:25.357 2770 2770 I chromium: [INFO:CONSOLE(2)] "WebSocket connection to 'ws://192.168.66.66:8123/api/websocket' failed: Error in connection establishment: net::ERR_INTERNET_DISCONNECTED", source: http://192.168.66.66:8123/frontend_es5/core.82323f4c.js (2)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: Unable to retrieve external auth
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: java.net.ConnectException: Failed to connect to /192.168.66.66:8123
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:297)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connect(RealConnection.kt:207)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.kt:226)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.kt:106)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.kt:74)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall.initExchange$okhttp(RealCall.kt:255)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:32)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at io.homeassistant.companion.android.common.data.HomeAssistantRetrofit$special$$inlined$-addInterceptor$1.intercept(OkHttpClient.kt:1087)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:517)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at java.lang.Thread.run(Thread.java:764)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: Caused by: java.net.ConnectException: failed to connect to /192.168.66.66 (port 8123) from /:: (port 0) after 10000ms: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connect(IoBridge.java:138)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:129)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:356)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:357)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at java.net.Socket.connect(Socket.java:616)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.platform.AndroidPlatform.connectSocket(AndroidPlatform.kt:63)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:295)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: ... 20 more
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: Caused by: android.system.ErrnoException: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at libcore.io.Linux.connect(Native Method)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at libcore.io.BlockGuardOs.connect(BlockGuardOs.java:126)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connectErrno(IoBridge.java:169)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connect(IoBridge.java:130)
12-20 20:16:25.359 2770 2770 E WebViewPresenterImpl: ... 28 more
12-20 20:16:25.362 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:25.362 2770 2770 D UrlRepository: Using external URL
12-20 20:16:25.444 2770 2792 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:25.474 2770 2213 E SensorReceiver: Exception while updating sensors.
12-20 20:16:25.474 2770 2213 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@d25995c
12-20 20:16:25.474 2770 2213 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateSensors(IntegrationRepositoryImpl.kt:517)
12-20 20:16:25.474 2770 2213 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateSensors$1.invokeSuspend(Unknown Source:15)
12-20 20:16:25.474 2770 2213 E SensorReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
12-20 20:16:25.474 2770 2213 E SensorReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
12-20 20:16:25.474 2770 2213 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
12-20 20:16:25.474 2770 2213 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
12-20 20:16:25.474 2770 2213 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
12-20 20:16:25.474 2770 2213 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
12-20 20:16:25.474 2770 2213 E SensorReceiver: Caused by: kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@d25995c
12-20 20:16:26.207 2770 2308 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:26.253 2770 2308 E SensorReceiver: Exception while updating sensors.
12-20 20:16:26.253 2770 2308 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: java.net.ConnectException: Failed to connect to /192.168.66.66:8123
12-20 20:16:26.253 2770 2308 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateSensors(IntegrationRepositoryImpl.kt:517)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateSensors$1.invokeSuspend(Unknown Source:15)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
12-20 20:16:26.253 2770 2308 E SensorReceiver: Caused by: java.net.ConnectException: Failed to connect to /192.168.66.66:8123
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:297)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.RealConnection.connect(RealConnection.kt:207)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.kt:226)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.kt:106)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.kt:74)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.RealCall.initExchange$okhttp(RealCall.kt:255)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:32)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at io.homeassistant.companion.android.common.data.HomeAssistantRetrofit$special$$inlined$-addInterceptor$1.intercept(OkHttpClient.kt:1089)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:517)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at java.lang.Thread.run(Thread.java:764)
12-20 20:16:26.253 2770 2308 E SensorReceiver: Caused by: java.net.ConnectException: failed to connect to /192.168.66.66 (port 8123) from /:: (port 0) after 10000ms: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at libcore.io.IoBridge.connect(IoBridge.java:138)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:129)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:356)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:357)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at java.net.Socket.connect(Socket.java:616)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.platform.AndroidPlatform.connectSocket(AndroidPlatform.kt:63)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:295)
12-20 20:16:26.253 2770 2308 E SensorReceiver: ... 20 more
12-20 20:16:26.253 2770 2308 E SensorReceiver: Caused by: android.system.ErrnoException: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at libcore.io.Linux.connect(Native Method)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at libcore.io.BlockGuardOs.connect(BlockGuardOs.java:126)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at libcore.io.IoBridge.connectErrno(IoBridge.java:169)
12-20 20:16:26.253 2770 2308 E SensorReceiver: at libcore.io.IoBridge.connect(IoBridge.java:130)
12-20 20:16:26.253 2770 2308 E SensorReceiver: ... 28 more
12-20 20:16:26.261 2770 1809 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:26.305 2770 3028 E SensorReceiver: Exception while updating sensors.
12-20 20:16:26.305 2770 3028 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@c5c0c19
12-20 20:16:26.305 2770 3028 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateSensors(IntegrationRepositoryImpl.kt:517)
12-20 20:16:26.305 2770 3028 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateSensors$1.invokeSuspend(Unknown Source:15)
12-20 20:16:26.305 2770 3028 E SensorReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
12-20 20:16:26.305 2770 3028 E SensorReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
12-20 20:16:26.305 2770 3028 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
12-20 20:16:26.305 2770 3028 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
12-20 20:16:26.305 2770 3028 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
12-20 20:16:26.305 2770 3028 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
12-20 20:16:26.305 2770 3028 E SensorReceiver: Caused by: kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@c5c0c19
12-20 20:16:26.401 2770 3003 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:26.437 2770 3003 E SensorReceiver: Exception while updating sensors.
12-20 20:16:26.437 2770 3003 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: java.net.ConnectException: Failed to connect to /192.168.66.66:8123
12-20 20:16:26.437 2770 3003 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateSensors(IntegrationRepositoryImpl.kt:517)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateSensors$1.invokeSuspend(Unknown Source:15)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
12-20 20:16:26.437 2770 3003 E SensorReceiver: Caused by: java.net.ConnectException: Failed to connect to /192.168.66.66:8123
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:297)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.RealConnection.connect(RealConnection.kt:207)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.kt:226)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.kt:106)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.kt:74)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.RealCall.initExchange$okhttp(RealCall.kt:255)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:32)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at io.homeassistant.companion.android.common.data.HomeAssistantRetrofit$special$$inlined$-addInterceptor$1.intercept(OkHttpClient.kt:1089)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:517)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at java.lang.Thread.run(Thread.java:764)
12-20 20:16:26.437 2770 3003 E SensorReceiver: Caused by: java.net.ConnectException: failed to connect to /192.168.66.66 (port 8123) from /:: (port 0) after 10000ms: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at libcore.io.IoBridge.connect(IoBridge.java:138)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:129)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:356)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:357)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at java.net.Socket.connect(Socket.java:616)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.platform.AndroidPlatform.connectSocket(AndroidPlatform.kt:63)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:295)
12-20 20:16:26.437 2770 3003 E SensorReceiver: ... 20 more
12-20 20:16:26.437 2770 3003 E SensorReceiver: Caused by: android.system.ErrnoException: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at libcore.io.Linux.connect(Native Method)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at libcore.io.BlockGuardOs.connect(BlockGuardOs.java:126)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at libcore.io.IoBridge.connectErrno(IoBridge.java:169)
12-20 20:16:26.437 2770 3003 E SensorReceiver: at libcore.io.IoBridge.connect(IoBridge.java:130)
12-20 20:16:26.437 2770 3003 E SensorReceiver: ... 28 more
12-20 20:16:26.498 2770 3029 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:26.515 2770 3003 E SensorReceiver: Exception while updating sensors.
12-20 20:16:26.515 2770 3003 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@d554342
12-20 20:16:26.515 2770 3003 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateSensors(IntegrationRepositoryImpl.kt:517)
12-20 20:16:26.515 2770 3003 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateSensors$1.invokeSuspend(Unknown Source:15)
12-20 20:16:26.515 2770 3003 E SensorReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
12-20 20:16:26.515 2770 3003 E SensorReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
12-20 20:16:26.515 2770 3003 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
12-20 20:16:26.515 2770 3003 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
12-20 20:16:26.515 2770 3003 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
12-20 20:16:26.515 2770 3003 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
12-20 20:16:26.515 2770 3003 E SensorReceiver: Caused by: kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@d554342
12-20 20:16:27.377 2770 2770 I chromium: [INFO:CONSOLE(2)] "WebSocket connection to 'ws://192.168.66.66:8123/api/websocket' failed: Error in connection establishment: net::ERR_INTERNET_DISCONNECTED", source: http://192.168.66.66:8123/frontend_es5/core.82323f4c.js (2)
12-20 20:16:27.382 2770 3031 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:27.382 2770 3031 D UrlRepository: Using external URL
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: Unable to retrieve external auth
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: java.net.ConnectException: Failed to connect to /192.168.66.66:8123
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:297)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connect(RealConnection.kt:207)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.kt:226)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.kt:106)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.kt:74)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall.initExchange$okhttp(RealCall.kt:255)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:32)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at io.homeassistant.companion.android.common.data.HomeAssistantRetrofit$special$$inlined$-addInterceptor$1.intercept(OkHttpClient.kt:1087)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:517)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at java.lang.Thread.run(Thread.java:764)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: Caused by: java.net.ConnectException: failed to connect to /192.168.66.66 (port 8123) from /:: (port 0) after 10000ms: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connect(IoBridge.java:138)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:129)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:356)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:357)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at java.net.Socket.connect(Socket.java:616)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.platform.AndroidPlatform.connectSocket(AndroidPlatform.kt:63)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:295)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: ... 20 more
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: Caused by: android.system.ErrnoException: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at libcore.io.Linux.connect(Native Method)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at libcore.io.BlockGuardOs.connect(BlockGuardOs.java:126)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connectErrno(IoBridge.java:169)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connect(IoBridge.java:130)
12-20 20:16:27.415 2770 2770 E WebViewPresenterImpl: ... 28 more
12-20 20:16:27.418 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:27.418 2770 2770 D UrlRepository: Using external URL
12-20 20:16:30.391 2770 3031 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:30.391 2770 3031 D UrlRepository: Using external URL
12-20 20:16:30.406 2770 2770 I chromium: [INFO:CONSOLE(2)] "WebSocket connection to 'ws://192.168.66.66:8123/api/websocket' failed: Error in connection establishment: net::ERR_INTERNET_DISCONNECTED", source: http://192.168.66.66:8123/frontend_es5/core.82323f4c.js (2)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: Unable to retrieve external auth
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: java.net.ConnectException: Failed to connect to /192.168.66.66:8123
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:297)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connect(RealConnection.kt:207)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.kt:226)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.kt:106)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.kt:74)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall.initExchange$okhttp(RealCall.kt:255)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:32)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at io.homeassistant.companion.android.common.data.HomeAssistantRetrofit$special$$inlined$-addInterceptor$1.intercept(OkHttpClient.kt:1087)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:517)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at java.lang.Thread.run(Thread.java:764)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: Caused by: java.net.ConnectException: failed to connect to /192.168.66.66 (port 8123) from /:: (port 0) after 10000ms: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connect(IoBridge.java:138)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:129)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:356)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:357)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at java.net.Socket.connect(Socket.java:616)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.platform.AndroidPlatform.connectSocket(AndroidPlatform.kt:63)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:295)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: ... 20 more
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: Caused by: android.system.ErrnoException: connect failed: ENETUNREACH (Network is unreachable)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at libcore.io.Linux.connect(Native Method)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at libcore.io.BlockGuardOs.connect(BlockGuardOs.java:126)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connectErrno(IoBridge.java:169)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: at libcore.io.IoBridge.connect(IoBridge.java:130)
12-20 20:16:30.408 2770 2770 E WebViewPresenterImpl: ... 28 more
12-20 20:16:30.411 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:30.411 2770 2770 D UrlRepository: Using external URL
12-20 20:16:33.686 2770 3003 D SensorWorker: Updating all Sensors.
12-20 20:16:33.689 2770 2786 I WM-Processor: Moving WorkSpec (519a5c7a-5df3-4180-a37c-d37bb65590f0) to the foreground
12-20 20:16:33.696 2770 3003 D LastUpdate: Last update is SensorWorker
12-20 20:16:33.704 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 20:16:34.296 2770 3003 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:34.382 2770 2812 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=519a5c7a-5df3-4180-a37c-d37bb65590f0, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 20:16:34.414 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 20:16:34.432 2770 3031 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:16:34.432 2770 3031 D UrlRepository: Using external URL
12-20 20:17:03.799 2770 2781 I zygote : Background concurrent copying GC freed 227974(8MB) AllocSpace objects, 2(104KB) LOS objects, 49% free, 10MB/21MB, paused 104us total 120.449ms
12-20 20:17:48.098 2770 2770 D UrlRepository: Using external URL
12-20 20:17:48.106 2770 1358 W libEGL : EGLNativeWindowType 0x80088808 disconnect failed
12-20 20:17:48.106 2770 1358 D OpenGLRenderer: endAllActiveAnimators on 0x7f69b600 (RippleDrawable) with handle 0x8790a200
12-20 20:17:48.125 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:17:48.125 2770 2770 D UrlRepository: Using external URL
12-20 20:17:48.152 2770 2770 I chromium: [INFO:CONSOLE(1)] "The key "viewport-fit" is not recognized and ignored.", source: http://192.168.66.66:8123/ (1)
12-20 20:17:48.161 2770 2770 I chromium: [INFO:CONSOLE(1)] "Uncaught SyntaxError: Unexpected token import", source: http://192.168.66.66:8123/ (1)
12-20 20:17:48.261 2770 2770 I chromium: [INFO:CONSOLE(2)] "Uncaught ReferenceError: regeneratorRuntime is not defined", source: http://192.168.66.66:8123/frontend_es5/app.dc5acec3.js (2)
12-20 20:17:58.139 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:17:58.218 2770 1358 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
12-20 20:24:36.481 2770 2781 I zygote : Background concurrent copying GC freed 514813(12MB) AllocSpace objects, 0(0B) LOS objects, 49% free, 8MB/17MB, paused 371us total 127ms
12-20 20:30:23.285 2770 1358 W libEGL : EGLNativeWindowType 0x840c2808 disconnect failed
12-20 20:30:23.285 2770 1358 D OpenGLRenderer: endAllActiveAnimators on 0x7f698180 (RippleDrawable) with handle 0x8790ada0
12-20 20:30:23.441 2770 2770 D UrlRepository: Using external URL
12-20 20:30:23.442 2770 2770 D UrlRepository: Using external URL
12-20 20:30:23.444 2770 2770 D UrlRepository: Using external URL
12-20 20:30:23.471 2770 2770 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:30:23.471 2770 2770 D UrlRepository: Using external URL
12-20 20:30:23.492 2770 1358 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
12-20 20:30:23.645 2770 3029 D SensorWorker: Updating all Sensors.
12-20 20:30:23.647 2770 2786 I WM-Processor: Moving WorkSpec (528b07ae-cd8e-4dbb-9279-2699d4edf1c6) to the foreground
12-20 20:30:23.652 2770 3029 D LastUpdate: Last update is SensorWorker
12-20 20:30:23.805 2770 2770 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android.minimal/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 20:30:23.868 2770 1358 W libEGL : EGLNativeWindowType 0x80925808 disconnect failed
12-20 20:30:24.111 2770 3029 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:30:24.170 2770 2786 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=528b07ae-cd8e-4dbb-9279-2699d4edf1c6, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 20:30:24.187 2770 2770 I WM-SystemFgDispatcher: Stopping foreground service
12-20 20:30:29.539 2770 2770 I zygote : Deoptimizing void androidx.fragment.app.FragmentStateManager.createView() due to JIT inline cache
12-20 20:30:29.540 2770 2770 I zygote : Deoptimizing kotlin.coroutines.CoroutineContext kotlinx.coroutines.CoroutineContextKt.newCoroutineContext(kotlinx.coroutines.CoroutineScope, kotlin.coroutines.CoroutineContext) due to JIT inline cache
12-20 20:30:29.541 2770 2770 I zygote : Deoptimizing void androidx.fragment.app.FragmentStateManager.moveToExpectedState() due to JIT inline cache
12-20 20:30:29.541 2770 2770 I zygote : Deoptimizing void androidx.fragment.app.SpecialEffectsController.updateFinalState() due to JIT inline cache
12-20 20:30:29.541 2770 2770 I zygote : Deoptimizing void androidx.fragment.app.SpecialEffectsController.markPostponedState() due to JIT inline cache
12-20 20:30:29.541 2770 2770 I zygote : Deoptimizing androidx.fragment.app.SpecialEffectsController$Operation$State androidx.fragment.app.SpecialEffectsController$Operation$State.from(android.view.View) due to JIT inline cache
12-20 20:30:29.542 2770 2770 I zygote : Deoptimizing void androidx.fragment.app.SpecialEffectsController$FragmentStateManagerOperation.onStart() due to JIT inline cache
12-20 20:30:29.543 2770 2770 I zygote : Deoptimizing void androidx.fragment.app.DefaultSpecialEffectsController.executeOperations(java.util.List, boolean) due to JIT inline cache
12-20 20:30:29.544 2770 2770 I zygote : Deoptimizing boolean androidx.fragment.app.DefaultSpecialEffectsController$SpecialEffectsInfo.isVisibilityUnchanged() due to JIT inline cache
12-20 20:30:29.547 2770 2770 I zygote : Deoptimizing void androidx.fragment.app.SpecialEffectsController$Operation$State.applyState(android.view.View) due to JIT inline cache
12-20 20:30:29.548 2770 3028 D LogcatReader: Read logcat for pid 2770
12-20 20:30:29.594 2770 3028 D LogcatReader: Done reading logcat for pid 2770
12-20 20:30:43.208 2770 1358 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
12-20 20:30:46.727 2770 2770 D LogFragment: User want to share log
12-20 20:30:46.743 2770 2770 I LogFragment: Create log file to: /storage/emulated/0/Android/data/io.homeassistant.companion.android.minimal/cache/logs/homeassistant_companion_log_11-20-2021_20-30-46.txt
12-20 20:30:46.748 2770 2770 I LogFragment: Open share dialog with log file
12-20 20:30:46.776 2770 1358 W libEGL : EGLNativeWindowType 0x7c6da808 disconnect failed
12-20 20:30:57.302 2770 19456 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b84a009
12-20 20:30:59.183 2770 2770 D LastUpdate: Last update is android.bluetooth.adapter.action.STATE_CHANGED
12-20 20:30:59.312 2770 2770 D LastUpdate: Last update is android.bluetooth.adapter.action.STATE_CHANGED
12-20 20:30:59.463 2770 2770 I zygote : Deoptimizing void androidx.fragment.app.FragmentStateManager.saveViewState() due to JIT inline cache
12-20 20:30:59.522 2770 1358 W libEGL : EGLNativeWindowType 0x865f8008 disconnect failed
12-20 20:30:59.588 2770 3028 D BluetoothManager: getConnectedDevices
12-20 20:30:59.667 2770 3028 D BeaconParser: Parsing beacon layout: m:2-3=0215,i:4-19,i:20-21,i:22-23,p:24-24
12-20 20:30:59.681 2770 3028 D BluetoothAdapter: isLeEnabled(): ON
12-20 20:30:59.686 2770 3028 D BluetoothAdapter: isLeEnabled(): ON
12-20 20:30:59.716 2770 2770 I BeaconTransmitter: Advertisement start succeeded.
12-20 20:30:59.793 2770 3029 D BluetoothManager: getConnectedDevices
12-20 20:31:00.137 2770 3028 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:31:00.208 2770 3029 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:31:03.811 2770 1358 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
12-20 20:31:04.150 2770 2770 D LastUpdate: Last update is android.bluetooth.device.action.ACL_CONNECTED
12-20 20:31:04.160 2770 2770 D TemplateWidget: Broadcast received:
12-20 20:31:04.160 2770 2770 D TemplateWidget: Broadcast action: android.bluetooth.device.action.ACL_CONNECTED
12-20 20:31:04.160 2770 2770 D TemplateWidget: AppWidgetId: -1
12-20 20:31:04.182 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.AppSensorManager.updateImportanceCheck(android.content.Context) due to JIT inline cache
12-20 20:31:04.186 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.AppSensorManager.requestSensorUpdate(android.content.Context) due to JIT inline cache
12-20 20:31:04.187 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.AppSensorManager.updateAppInactive(android.content.Context, android.app.usage.UsageStatsManager) due to JIT inline cache
12-20 20:31:04.202 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.AudioSensorManager.requestSensorUpdate(android.content.Context) due to JIT inline cache
12-20 20:31:04.252 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.BatterySensorManager.requestSensorUpdate(android.content.Context) due to JIT inline cache
12-20 20:31:04.288 2770 3029 D BluetoothManager: getConnectedDevices
12-20 20:31:04.328 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.DNDSensorManager.updateDNDState(android.content.Context) due to JIT inline cache
12-20 20:31:04.333 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.KeyguardSensorManager.requestSensorUpdate(android.content.Context) due to JIT inline cache
12-20 20:31:04.368 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.MobileDataManager.checkState(android.content.Context, io.homeassistant.companion.android.sensors.SensorManager$BasicSensor, java.lang.String, java.lang.String) due to JIT inline cache
12-20 20:31:04.405 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.NotificationSensorManager.updateMediaSession(android.content.Context) due to JIT inline cache
12-20 20:31:04.451 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.PressureSensorManager.updatePressureSensor() due to JIT inline cache
12-20 20:31:04.454 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.ProximitySensorManager.updateProximitySensor() due to JIT inline cache
12-20 20:31:04.455 2770 3029 I zygote : Deoptimizing void io.homeassistant.companion.android.sensors.StepsSensorManager.updateStepsSensor() due to JIT inline cache
12-20 20:31:04.476 2770 3029 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:31:05.759 2770 2770 D LastUpdate: Last update is android.bluetooth.device.action.ACL_DISCONNECTED
12-20 20:31:05.786 2770 2770 D TemplateWidget: Broadcast received:
12-20 20:31:05.786 2770 2770 D TemplateWidget: Broadcast action: android.bluetooth.device.action.ACL_DISCONNECTED
12-20 20:31:05.786 2770 2770 D TemplateWidget: AppWidgetId: -1
12-20 20:31:05.951 2770 3029 D BluetoothManager: getConnectedDevices
12-20 20:31:06.156 2770 3029 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 20:31:16.803 2770 3029 D LogcatReader: Read logcat for pid 2770
12-20 20:31:16.843 2770 3029 D LogcatReader: Done reading logcat for pid 2770
12-20 20:31:16.957 2770 2781 I zygote : Background concurrent copying GC freed 152991(6MB) AllocSpace objects, 9(672KB) LOS objects, 49% free, 12MB/24MB, paused 110us total 129.361ms
12-20 20:31:20.890 2770 1358 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
12-20 20:31:22.699 2770 2770 D LogFragment: User want to share log
12-20 20:31:22.714 2770 2770 I LogFragment: Create log file to: /storage/emulated/0/Android/data/io.homeassistant.companion.android.minimal/cache/logs/homeassistant_companion_log_11-20-2021_20-31-22.txt
12-20 20:31:22.722 2770 2770 I LogFragment: Open share dialog with log file
**Screenshot of problem:**
See above.
**Additional information:**
At first with the older Home Assistant 2021.10 you could click refresh, and it would start anyway. But now you can click forever and it won't. Even deleting app, starting over new won't solve it.
