LOHAS LED Daylight RGB A19 Bulb Color Changing 60W
Lohas 9W RGBW
just flashed these RGB bulbs with Tasmota via USB as Tuya COnvert 2.0 did not work. I`m using the template and following Light setup in HA and the bulb is not showing up as COLOR light bulb. Please help. Using Tasmota 6.7.1
Were you ever able to get this resolved? I’m on the latest tasmota version 6.7.1, same template as you, and it shows up as color but I get nothing for the white channels. Very frustrating.
I suspect it has to do with color_temp in my config. Here’s what I have FWIW:
