Hi.
I’ve a lolin32 attached to a 4 channel relay board. Ok the esp I installed the Time Based cover platform. I’m pasting below the ESPHome configuration.
Basically, when I switch on the board, all the four relay red led are turned on, and this sounds strange to me, because other installations I checked have the LEDs off by default. Whenever I trigger the GPIOs, the led turn off according to the active pin for the configured duration of the action, then it comes back on.
Despite the LED status, and despite the fact I can hear the relays physically triggering, the relay ports are always stuck: B+C is closed, B+A is open.
I’ve a second board and behaves exactly the same. I haven’t tried another lolin32…
Given the second is doing the same, I think it’s something I haven’t done correctly.
I tried measuring voltage on the relay board and everything seems fine. It gets the 3.3V, and when the relay is triggered by ESPHome its current is set to 0. But the frontend ports never change.
I’m wondering what I can have configured badly. Any hint on how to debug this is welcome.
substitutions:
  friendly_name: ESPHome relay tende
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
  project:
    version: '1.0'
esp32:
  board: lolin32
  # board: esp32dev
  # framework:
    # type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
  - platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
  # Set up a wifi access point
  ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
  import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
  authorizer: none
# To have a "next url" for improv serial
web_server:
cover:
  - platform: time_based
    open_action:
      - switch.turn_on: tenda_cucina_open
    open_duration: 32sec
    close_action:
      - switch.turn_on: tenda_cucina_close
    close_duration: 32sec
    stop_action:
      - switch.turn_off: tenda_cucina_open
      - switch.turn_off: tenda_cucina_close
    open_action:
      - switch.turn_on: tenda_ragazzi_open
    open_duration: 29sec
    close_action:
      - switch.turn_on: tenda_ragazzi_close
    close_duration: 29sec
    stop_action:
      - switch.turn_off: tenda_ragazzi_open
      - switch.turn_off: tenda_ragazzi_close
switch:
  - platform: gpio
    pin: GPIO25
    restore_mode: ALWAYS_OFF
    interlock: &interlock_cucina [tenda_cucina_open, tenda_cucina_close]
    interlock_wait_time: 200ms
  - platform: gpio
    pin: GPIO27
    interlock: *interlock_cucina
  - platform: gpio
    interlock: &interlock_ragazzi [tenda_ragazzi_open, tenda_ragazzi_close]
    pin: GPIO26
  - platform: gpio
    interlock: *interlock_ragazzi
    pin: GPIO14
  # WiFi Signal sensor.
  - platform: wifi_signal
    name: Relay WiFi Signal
    update_interval: 60s
