Whenever i switch on or off just one single fibaro z-wave switch, it works just fine. If i turn on or off several switches at the same time, the first one is instant, but the next turns on/off after a ~10 second delay. If i wait for more than ten secons before i switch on the second one, it’s more or less instant.
Does anybody else have this issue?
Switches: Fibaro FGWPE/F Wall Plug Gen5
USB: Aeotec Z-Wave stick gen5
Configuration handled through integrations in the frontend.
2018-11-22 09:49:23.953 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2018-11-22 09:49:23.954 Info, Node002, SwitchBinary::Set - Setting node 2 to On
2018-11-22 09:49:23.954 Detail, Node002, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_SWITCH_BINARY
2018-11-22 09:49:23.954 Detail, Node002, Queuing (Send) SwitchBinaryCmd_Set (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x25, 0x01, 0xff, 0x25, 0x3c, 0x25
2018-11-22 09:49:23.954 Detail, Node002, Queuing (Send) SwitchBinaryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x25, 0x02, 0x25, 0x3d, 0xda
2018-11-22 09:49:23.955 Detail,
2018-11-22 09:49:23.955 Info, Node002, Processing (Send) Nonce Request message (Callback ID=0x3c, Expected Reply=0x13)
2018-11-22 09:49:23.955 Info, Node002, Sending (Send) message (Callback ID=0x3c, Expected Reply=0x13) - Nonce_Get(SwitchBinaryCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x98, 0x40, 0x05, 0x02:
2018-11-22 09:49:23.962 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:23.962 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:23.965 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2018-11-22 09:49:23.965 Info, Node003, SwitchBinary::Set - Setting node 3 to On
2018-11-22 09:49:23.965 Detail, Node003, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_SWITCH_BINARY
2018-11-22 09:49:23.965 Detail, Node003, Queuing (Send) SwitchBinaryCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x25, 0x01, 0xff, 0x25, 0x3e, 0x26
2018-11-22 09:49:23.965 Detail, Node003, Queuing (Send) SwitchBinaryCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x25, 0x02, 0x25, 0x3f, 0xd9
2018-11-22 09:49:23.979 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2018-11-22 09:49:23.979 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2018-11-22 09:49:23.979 Info, Node002, Request RTT 23 Average Request RTT 52
2018-11-22 09:49:23.992 Detail, Node002, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x02, 0x0a, 0x98, 0x80, 0xcf, 0xd4, 0xe6, 0xb8, 0x07, 0x6e, 0x4b, 0xb8, 0x24
2018-11-22 09:49:23.999 Info, Node002, Received SecurityCmd_NonceReport from node 2
2018-11-22 09:49:23.999 Info, Node002, Sending (Send) message (Callback ID=0x40, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x25, 0x01, 0xff, 0x25, 0x40, 0x59
2018-11-22 09:49:24.009 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:24.009 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:24.027 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x40, 0x00, 0x00, 0x02, 0xa9
2018-11-22 09:49:24.027 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x40 received (expected 0x40)
2018-11-22 09:49:24.027 Info, Node002, Request RTT 72 Average Request RTT 62
2018-11-22 09:49:24.027 Detail, Expected callbackId was received
2018-11-22 09:49:24.027 Detail, Expected reply was received
2018-11-22 09:49:24.027 Detail, Message transaction complete
2018-11-22 09:49:24.027 Detail, Node002, Removing current message
2018-11-22 09:49:24.027 Info, Node002, Processing (Send) Nonce Request message (Callback ID=0x3d, Expected Reply=0x04)
2018-11-22 09:49:24.028 Info, Node002, Sending (Send) message (Callback ID=0x3d, Expected Reply=0x04) - Nonce_Get(SwitchBinaryCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x98, 0x40, 0x05, 0x02:
2018-11-22 09:49:24.036 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:24.036 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:24.052 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x03, 0xea
2018-11-22 09:49:24.052 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2018-11-22 09:49:24.052 Info, Node002, Request RTT 24 Average Request RTT 43
2018-11-22 09:49:24.073 Detail, Node002, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x02, 0x0a, 0x98, 0x80, 0xa2, 0x62, 0x96, 0x06, 0x1a, 0x0b, 0x5a, 0x80, 0x60
2018-11-22 09:49:24.081 Info, Node002, Received SecurityCmd_NonceReport from node 2
2018-11-22 09:49:24.081 Info, Node002, Sending (Send) message (Callback ID=0x41, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x25, 0x02, 0x25, 0x41, 0xa6
2018-11-22 09:49:24.088 Detail, Node002, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x02, 0x02, 0x98, 0x40, 0x2b
2018-11-22 09:49:24.088 Info, Node002, Received SecurityCmd_NonceGet from node 2
2018-11-22 09:49:24.088 Info, NONCES: 0x47, 0x8d, 0x7a, 0xa0, 0x5d, 0x83, 0xf3, 0xea
2018-11-22 09:49:24.088 Info, NONCES: 0x28, 0x66, 0x21, 0x1b, 0xff, 0x37, 0x83, 0xd6
2018-11-22 09:49:24.089 Info, NONCES: 0x87, 0xc5, 0x66, 0xe4, 0x48, 0x5a, 0xce, 0xeb
2018-11-22 09:49:24.089 Info, NONCES: 0x26, 0xe1, 0xa4, 0x6e, 0x9e, 0x47, 0xc9, 0x4e
2018-11-22 09:49:24.089 Info, NONCES: 0x20, 0xcb, 0x2a, 0xbe, 0x13, 0xf3, 0x0d, 0x85
2018-11-22 09:49:24.089 Info, NONCES: 0x18, 0x22, 0x85, 0x14, 0x11, 0x34, 0x76, 0xd1
2018-11-22 09:49:24.089 Info, NONCES: 0xfa, 0xbe, 0xe7, 0xfb, 0xaa, 0x7f, 0x29, 0xd4
2018-11-22 09:49:24.089 Info, NONCES: 0x6a, 0xb2, 0xac, 0xa3, 0x58, 0x2f, 0x9b, 0xa0
2018-11-22 09:49:24.089 Info, Node002, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x02, 0x0a, 0x98, 0x80, 0x6a, 0xb2, 0xac, 0xa3, 0x58, 0x2f, 0x9b, 0xa0, 0x05, 0x01, 0x72:
2018-11-22 09:49:24.091 Detail, Node002, CAN received...triggering resend
2018-11-22 09:49:24.091 Info, NONCES: 0xbb, 0x54, 0xbd, 0x33, 0xeb, 0xaf, 0xa7, 0x41
2018-11-22 09:49:24.091 Info, NONCES: 0x28, 0x66, 0x21, 0x1b, 0xff, 0x37, 0x83, 0xd6
2018-11-22 09:49:24.091 Info, NONCES: 0x87, 0xc5, 0x66, 0xe4, 0x48, 0x5a, 0xce, 0xeb
2018-11-22 09:49:24.091 Info, NONCES: 0x26, 0xe1, 0xa4, 0x6e, 0x9e, 0x47, 0xc9, 0x4e
2018-11-22 09:49:24.091 Info, NONCES: 0x20, 0xcb, 0x2a, 0xbe, 0x13, 0xf3, 0x0d, 0x85
2018-11-22 09:49:24.091 Info, NONCES: 0x18, 0x22, 0x85, 0x14, 0x11, 0x34, 0x76, 0xd1
2018-11-22 09:49:24.091 Info, NONCES: 0xfa, 0xbe, 0xe7, 0xfb, 0xaa, 0x7f, 0x29, 0xd4
2018-11-22 09:49:24.091 Info, NONCES: 0x6a, 0xb2, 0xac, 0xa3, 0x58, 0x2f, 0x9b, 0xa0
2018-11-22 09:49:24.091 Info, Node002, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x02, 0x0a, 0x98, 0x80, 0xbb, 0x54, 0xbd, 0x33, 0xeb, 0xaf, 0xa7, 0x41, 0x05, 0x01, 0x2a:
2018-11-22 09:49:24.100 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:24.107 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:24.108 Detail, Node002, CAN received...triggering resend
2018-11-22 09:49:24.108 Info, NONCES: 0xbb, 0x54, 0xbd, 0x33, 0xeb, 0xaf, 0xa7, 0x41
2018-11-22 09:49:24.108 Info, NONCES: 0x88, 0x16, 0x42, 0xe0, 0xaf, 0x17, 0x1c, 0x5c
2018-11-22 09:49:24.108 Info, NONCES: 0x87, 0xc5, 0x66, 0xe4, 0x48, 0x5a, 0xce, 0xeb
2018-11-22 09:49:24.108 Info, NONCES: 0x26, 0xe1, 0xa4, 0x6e, 0x9e, 0x47, 0xc9, 0x4e
2018-11-22 09:49:24.108 Info, NONCES: 0x20, 0xcb, 0x2a, 0xbe, 0x13, 0xf3, 0x0d, 0x85
2018-11-22 09:49:24.108 Info, NONCES: 0x18, 0x22, 0x85, 0x14, 0x11, 0x34, 0x76, 0xd1
2018-11-22 09:49:24.108 Info, NONCES: 0xfa, 0xbe, 0xe7, 0xfb, 0xaa, 0x7f, 0x29, 0xd4
2018-11-22 09:49:24.108 Info, NONCES: 0x6a, 0xb2, 0xac, 0xa3, 0x58, 0x2f, 0x9b, 0xa0
2018-11-22 09:49:24.109 Info, Node002, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x02, 0x0a, 0x98, 0x80, 0x88, 0x16, 0x42, 0xe0, 0xaf, 0x17, 0x1c, 0x5c, 0x05, 0x01, 0x2d:
2018-11-22 09:49:24.117 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:24.117 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:24.122 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x00, 0xea
2018-11-22 09:49:24.122 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-11-22 09:49:24.122 Info, Node002, Request RTT 13 Average Request RTT 28
2018-11-22 09:49:24.213 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x0a, 0xe0
2018-11-22 09:49:24.214 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-11-22 09:49:24.214 Info, Node002, Request RTT 105 Average Request RTT 66
2018-11-22 09:49:24.233 Detail, Node002, Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x02, 0x17, 0x98, 0x81, 0xe5, 0x0d, 0x7e, 0x65, 0xca, 0x4c, 0x61, 0x76, 0x14, 0xc3, 0xd0, 0x56, 0x6a, 0x02, 0x43, 0x2d, 0x87, 0x41, 0x78, 0xec, 0xfd, 0x70
2018-11-22 09:49:24.233 Info, Raw: 0x98, 0x81, 0xe5, 0x0d, 0x7e, 0x65, 0xca, 0x4c, 0x61, 0x76, 0x14, 0xc3, 0xd0, 0x56, 0x6a, 0x02, 0x43, 0x2d, 0x87, 0x41, 0x78, 0xec, 0xfd, 0x70
2018-11-22 09:49:24.233 Detail, Node002, Decrypted Packet: 0x00, 0x25, 0x03, 0xff
2018-11-22 09:49:24.234 Detail,
2018-11-22 09:49:24.234 Info, Node002, Response RTT 124 Average Response RTT 284
2018-11-22 09:49:24.234 Info, Node002, Received SwitchBinary report from node 2: level=On
2018-11-22 09:49:24.234 Detail, Node002, Refreshed Value: old value=false, new value=true, type=bool
2018-11-22 09:49:24.234 Detail, Node002, Changes to this value are not verified
2018-11-22 09:49:24.234 Detail, Node002, Notification: ValueChanged
2018-11-22 09:49:24.251 Detail, Node002, Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x02, 0x17, 0x98, 0x81, 0x1e, 0x29, 0x79, 0x12, 0x5d, 0x1e, 0xff, 0x62, 0x76, 0x98, 0x8e, 0x7c, 0x88, 0xc3, 0xfe, 0xbc, 0x59, 0xcc, 0x03, 0x1b, 0x0f, 0xff
2018-11-22 09:49:24.251 Info, Raw: 0x98, 0x81, 0x1e, 0x29, 0x79, 0x12, 0x5d, 0x1e, 0xff, 0x62, 0x76, 0x98, 0x8e, 0x7c, 0x88, 0xc3, 0xfe, 0xbc, 0x59, 0xcc, 0x03, 0x1b, 0x0f, 0xff
2018-11-22 09:49:24.251 Detail, Node002, Decrypted Packet: 0x00, 0x25, 0x03, 0xff
2018-11-22 09:49:24.251 Info, Node002, Response RTT 142 Average Response RTT 213
2018-11-22 09:49:24.251 Info, Node002, Received SwitchBinary report from node 2: level=On
2018-11-22 09:49:24.252 Detail, Node002, Refreshed Value: old value=true, new value=true, type=bool
2018-11-22 09:49:24.252 Detail, Node002, Changes to this value are not verified
2018-11-22 09:49:24.252 Detail, Node002, Notification: ValueChanged
2018-11-22 09:49:24.840 Detail, Node002, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x08, 0xb8, 0x51
2018-11-22 09:49:24.840 Info, Node002, Response RTT 730 Average Response RTT 471
2018-11-22 09:49:24.840 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=223.2W
2018-11-22 09:49:24.840 Detail, Node002, Refreshed Value: old value=0.0, new value=223.2, type=decimal
2018-11-22 09:49:24.840 Detail, Node002, Changes to this value are not verified
2018-11-22 09:49:24.840 Detail, Node002, Notification: ValueChanged
2018-11-22 09:49:34.028 Detail,
2018-11-22 09:49:34.028 Info, Node002, Processing (Send) Nonce Request message (Attempt 2, Callback ID=0x42, Expected Reply=0x04)
2018-11-22 09:49:34.028 Info, Node002, Sending (Send) message (Callback ID=0x42, Expected Reply=0x04) - Nonce_Get(SwitchBinaryCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x98, 0x40, 0x05, 0x02:
2018-11-22 09:49:34.029 Detail, Node002, Notification: Notification - TimeOut
2018-11-22 09:49:34.036 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:34.036 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:34.051 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2018-11-22 09:49:34.052 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2018-11-22 09:49:34.052 Info, Node002, Request RTT 23 Average Request RTT 44
2018-11-22 09:49:34.066 Detail, Node002, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x02, 0x0a, 0x98, 0x80, 0x58, 0xb5, 0x64, 0x4b, 0xc3, 0x21, 0xbd, 0xc0, 0xa6
2018-11-22 09:49:34.066 Info, Node002, Received SecurityCmd_NonceReport from node 2
2018-11-22 09:49:34.066 Info, Node002, Sending (Send) message (Callback ID=0x43, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x25, 0x02, 0x25, 0x43, 0xa4
2018-11-22 09:49:34.077 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:34.077 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:34.095 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x43, 0x00, 0x00, 0x02, 0xaa
2018-11-22 09:49:34.095 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x43 received (expected 0x43)
2018-11-22 09:49:34.095 Info, Node002, Request RTT 66 Average Request RTT 55
2018-11-22 09:49:34.095 Detail, Expected callbackId was received
2018-11-22 09:49:34.107 Detail, Node002, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x02, 0x02, 0x98, 0x40, 0x2b
2018-11-22 09:49:34.108 Info, Node002, Received SecurityCmd_NonceGet from node 2
2018-11-22 09:49:34.108 Info, NONCES: 0xbb, 0x54, 0xbd, 0x33, 0xeb, 0xaf, 0xa7, 0x41
2018-11-22 09:49:34.108 Info, NONCES: 0x88, 0x16, 0x42, 0xe0, 0xaf, 0x17, 0x1c, 0x5c
2018-11-22 09:49:34.108 Info, NONCES: 0xfc, 0x00, 0xd3, 0x54, 0x30, 0x6f, 0xf5, 0xeb
2018-11-22 09:49:34.108 Info, NONCES: 0x26, 0xe1, 0xa4, 0x6e, 0x9e, 0x47, 0xc9, 0x4e
2018-11-22 09:49:34.108 Info, NONCES: 0x20, 0xcb, 0x2a, 0xbe, 0x13, 0xf3, 0x0d, 0x85
2018-11-22 09:49:34.108 Info, NONCES: 0x18, 0x22, 0x85, 0x14, 0x11, 0x34, 0x76, 0xd1
2018-11-22 09:49:34.108 Info, NONCES: 0xfa, 0xbe, 0xe7, 0xfb, 0xaa, 0x7f, 0x29, 0xd4
2018-11-22 09:49:34.108 Info, NONCES: 0x6a, 0xb2, 0xac, 0xa3, 0x58, 0x2f, 0x9b, 0xa0
2018-11-22 09:49:34.109 Info, Node002, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x02, 0x0a, 0x98, 0x80, 0xfc, 0x00, 0xd3, 0x54, 0x30, 0x6f, 0xf5, 0xeb, 0x05, 0x01, 0xd3:
2018-11-22 09:49:34.118 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:34.118 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:34.134 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0xe8
2018-11-22 09:49:34.134 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-11-22 09:49:34.134 Info, Node002, Request RTT 105 Average Request RTT 80
2018-11-22 09:49:34.153 Detail, Node002, Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x02, 0x17, 0x98, 0x81, 0xea, 0x87, 0xf2, 0x09, 0x8d, 0xb3, 0x95, 0x25, 0x22, 0xa0, 0xdd, 0x83, 0xfc, 0x78, 0x31, 0xc8, 0xf7, 0x7e, 0xde, 0x73, 0x16, 0x61
2018-11-22 09:49:34.153 Info, Raw: 0x98, 0x81, 0xea, 0x87, 0xf2, 0x09, 0x8d, 0xb3, 0x95, 0x25, 0x22, 0xa0, 0xdd, 0x83, 0xfc, 0x78, 0x31, 0xc8, 0xf7, 0x7e, 0xde, 0x73, 0x16, 0x61
2018-11-22 09:49:34.153 Detail, Node002, Decrypted Packet: 0x00, 0x25, 0x03, 0xff
2018-11-22 09:49:34.154 Info, Node002, Response RTT 124 Average Response RTT 297
2018-11-22 09:49:34.154 Info, Node002, Received SwitchBinary report from node 2: level=On
2018-11-22 09:49:34.154 Detail, Node002, Refreshed Value: old value=true, new value=true, type=bool
2018-11-22 09:49:34.154 Detail, Node002, Changes to this value are not verified
2018-11-22 09:49:34.154 Detail, Node002, Expected reply and command class was received
2018-11-22 09:49:34.154 Detail, Node002, Message transaction complete
2018-11-22 09:49:34.154 Detail, Node002, Removing current message
2018-11-22 09:49:34.154 Detail, Node002, Notification: ValueChanged
2018-11-22 09:49:34.163 Detail,
2018-11-22 09:49:34.163 Info, Node003, Processing (Send) Nonce Request message (Callback ID=0x3e, Expected Reply=0x13)
2018-11-22 09:49:34.163 Info, Node003, Sending (Send) message (Callback ID=0x3e, Expected Reply=0x13) - Nonce_Get(SwitchBinaryCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x98, 0x40, 0x05, 0x02:
2018-11-22 09:49:34.171 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:34.171 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:34.186 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2018-11-22 09:49:34.186 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2018-11-22 09:49:34.186 Info, Node003, Request RTT 23 Average Request RTT 52
2018-11-22 09:49:34.200 Detail, Node003, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x03, 0x0a, 0x98, 0x80, 0x58, 0x0a, 0x73, 0x44, 0x3f, 0xab, 0xea, 0xe1, 0x00
2018-11-22 09:49:34.201 Info, Node003, Received SecurityCmd_NonceReport from node 3
2018-11-22 09:49:34.201 Info, Node003, Sending (Send) message (Callback ID=0x44, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x25, 0x01, 0xff, 0x25, 0x44, 0x5c
2018-11-22 09:49:34.212 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:34.212 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:34.230 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x44, 0x00, 0x00, 0x02, 0xad
2018-11-22 09:49:34.230 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x44 received (expected 0x44)
2018-11-22 09:49:34.230 Info, Node003, Request RTT 66 Average Request RTT 59
2018-11-22 09:49:34.230 Detail, Expected callbackId was received
2018-11-22 09:49:34.230 Detail, Expected reply was received
2018-11-22 09:49:34.230 Detail, Message transaction complete
2018-11-22 09:49:34.230 Detail, Node003, Removing current message
2018-11-22 09:49:34.230 Info, Node003, Processing (Send) Nonce Request message (Callback ID=0x3f, Expected Reply=0x04)
2018-11-22 09:49:34.231 Info, Node003, Sending (Send) message (Callback ID=0x3f, Expected Reply=0x04) - Nonce_Get(SwitchBinaryCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x98, 0x40, 0x05, 0x02:
2018-11-22 09:49:34.239 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:34.239 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:34.257 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2018-11-22 09:49:34.258 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2018-11-22 09:49:34.258 Info, Node003, Request RTT 26 Average Request RTT 42
2018-11-22 09:49:34.269 Detail, Node003, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x03, 0x02, 0x98, 0x40, 0x2a
2018-11-22 09:49:34.269 Info, Node003, Received SecurityCmd_NonceGet from node 3
2018-11-22 09:49:34.269 Info, NONCES: 0x11, 0x05, 0x75, 0x10, 0x3c, 0xf8, 0xe6, 0xd9
2018-11-22 09:49:34.269 Info, NONCES: 0x70, 0xee, 0xee, 0xb8, 0x48, 0xbd, 0xa3, 0x5a
2018-11-22 09:49:34.270 Info, NONCES: 0x5a, 0xaf, 0xf4, 0x96, 0xa8, 0xdb, 0x70, 0xec
2018-11-22 09:49:34.270 Info, NONCES: 0x1b, 0x20, 0x7e, 0xc2, 0xfc, 0xef, 0xaf, 0x62
2018-11-22 09:49:34.270 Info, NONCES: 0x2a, 0x64, 0xe9, 0xd1, 0x5b, 0x8d, 0x94, 0x73
2018-11-22 09:49:34.270 Info, NONCES: 0x48, 0x8b, 0xb8, 0x1c, 0x78, 0x97, 0xf1, 0x73
2018-11-22 09:49:34.270 Info, NONCES: 0xdc, 0x34, 0xcb, 0x8c, 0x4c, 0xe7, 0xe8, 0xdf
2018-11-22 09:49:34.270 Info, NONCES: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2018-11-22 09:49:34.270 Info, Node003, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x03, 0x0a, 0x98, 0x80, 0xdc, 0x34, 0xcb, 0x8c, 0x4c, 0xe7, 0xe8, 0xdf, 0x05, 0x01, 0xdb:
2018-11-22 09:49:34.279 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:34.279 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:34.295 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0xe8
2018-11-22 09:49:34.296 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-11-22 09:49:34.296 Info, Node003, Request RTT 64 Average Request RTT 53
2018-11-22 09:49:34.314 Detail, Node003, Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x03, 0x17, 0x98, 0x81, 0x53, 0xd3, 0x33, 0x4d, 0xf6, 0xa4, 0xb9, 0x28, 0xbd, 0xda, 0x2e, 0x50, 0xdc, 0xa0, 0x2a, 0x09, 0x6a, 0x4a, 0x51, 0xb1, 0xa2, 0xf2
2018-11-22 09:49:34.315 Info, Raw: 0x98, 0x81, 0x53, 0xd3, 0x33, 0x4d, 0xf6, 0xa4, 0xb9, 0x28, 0xbd, 0xda, 0x2e, 0x50, 0xdc, 0xa0, 0x2a, 0x09, 0x6a, 0x4a, 0x51, 0xb1, 0xa2, 0xf2
2018-11-22 09:49:34.315 Detail, Node003, Decrypted Packet: 0x00, 0x25, 0x03, 0xff
2018-11-22 09:49:34.315 Info, Node003, Response RTT 84 Average Response RTT 358
2018-11-22 09:49:34.315 Info, Node003, Received SwitchBinary report from node 3: level=On
2018-11-22 09:49:34.315 Detail, Node003, Refreshed Value: old value=false, new value=true, type=bool
2018-11-22 09:49:34.315 Detail, Node003, Changes to this value are not verified
2018-11-22 09:49:34.315 Detail, Node003, Notification: ValueChanged
2018-11-22 09:49:34.335 Detail, Node003, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x03, 0x0a, 0x98, 0x80, 0x82, 0x82, 0xb9, 0xa7, 0x3e, 0xe0, 0x2d, 0x1c, 0x0b
2018-11-22 09:49:34.335 Info, Node003, Received SecurityCmd_NonceReport from node 3
2018-11-22 09:49:34.335 Info, Node003, Sending (Send) message (Callback ID=0x45, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x25, 0x02, 0x25, 0x45, 0xa3
2018-11-22 09:49:34.346 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:34.346 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:34.364 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x45, 0x00, 0x00, 0x03, 0xad
2018-11-22 09:49:34.364 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x45 received (expected 0x45)
2018-11-22 09:49:34.364 Info, Node003, Request RTT 133 Average Request RTT 93
2018-11-22 09:49:34.364 Detail, Expected callbackId was received
2018-11-22 09:49:34.378 Detail, Node003, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x03, 0x02, 0x98, 0x40, 0x2a
2018-11-22 09:49:34.378 Info, Node003, Received SecurityCmd_NonceGet from node 3
2018-11-22 09:49:34.378 Info, NONCES: 0x11, 0x05, 0x75, 0x10, 0x3c, 0xf8, 0xe6, 0xd9
2018-11-22 09:49:34.378 Info, NONCES: 0x70, 0xee, 0xee, 0xb8, 0x48, 0xbd, 0xa3, 0x5a
2018-11-22 09:49:34.378 Info, NONCES: 0x5a, 0xaf, 0xf4, 0x96, 0xa8, 0xdb, 0x70, 0xec
2018-11-22 09:49:34.378 Info, NONCES: 0x1b, 0x20, 0x7e, 0xc2, 0xfc, 0xef, 0xaf, 0x62
2018-11-22 09:49:34.378 Info, NONCES: 0x2a, 0x64, 0xe9, 0xd1, 0x5b, 0x8d, 0x94, 0x73
2018-11-22 09:49:34.378 Info, NONCES: 0x48, 0x8b, 0xb8, 0x1c, 0x78, 0x97, 0xf1, 0x73
2018-11-22 09:49:34.378 Info, NONCES: 0xdc, 0x34, 0xcb, 0x8c, 0x4c, 0xe7, 0xe8, 0xdf
2018-11-22 09:49:34.378 Info, NONCES: 0x7f, 0x4a, 0x2e, 0xaf, 0xba, 0x23, 0x9a, 0x7e
2018-11-22 09:49:34.379 Info, Node003, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x03, 0x0a, 0x98, 0x80, 0x7f, 0x4a, 0x2e, 0xaf, 0xba, 0x23, 0x9a, 0x7e, 0x05, 0x01, 0x21:
2018-11-22 09:49:34.387 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-22 09:49:34.387 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-22 09:49:34.403 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0xe8
2018-11-22 09:49:34.403 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-11-22 09:49:34.404 Info, Node003, Request RTT 172 Average Request RTT 132
2018-11-22 09:49:34.422 Detail, Node003, Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x03, 0x17, 0x98, 0x81, 0x2c, 0xa0, 0x41, 0x90, 0xcd, 0x89, 0xea, 0x57, 0x7c, 0xaf, 0xf5, 0xb6, 0x7f, 0x92, 0xe1, 0xfe, 0x57, 0xb5, 0xc9, 0xcd, 0xbe, 0x75
2018-11-22 09:49:34.423 Info, Raw: 0x98, 0x81, 0x2c, 0xa0, 0x41, 0x90, 0xcd, 0x89, 0xea, 0x57, 0x7c, 0xaf, 0xf5, 0xb6, 0x7f, 0x92, 0xe1, 0xfe, 0x57, 0xb5, 0xc9, 0xcd, 0xbe, 0x75
2018-11-22 09:49:34.423 Detail, Node003, Decrypted Packet: 0x00, 0x25, 0x03, 0xff
2018-11-22 09:49:34.423 Info, Node003, Response RTT 192 Average Response RTT 275
2018-11-22 09:49:34.423 Info, Node003, Received SwitchBinary report from node 3: level=On
2018-11-22 09:49:34.423 Detail, Node003, Refreshed Value: old value=true, new value=true, type=bool
2018-11-22 09:49:34.423 Detail, Node003, Changes to this value are not verified
2018-11-22 09:49:34.423 Detail, Node003, Expected reply and command class was received
2018-11-22 09:49:34.423 Detail, Node003, Message transaction complete
2018-11-22 09:49:34.423 Detail, Node003, Removing current message
2018-11-22 09:49:34.424 Detail, Node003, Notification: ValueChanged
2018-11-22 09:49:35.046 Detail, Node003, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x03, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x3b, 0xdb
2018-11-22 09:49:35.046 Info, Node003, Received SensorMultiLevel report from node 3, instance 1, Power: value=5.9W
2018-11-22 09:49:35.046 Detail, Node003, Refreshed Value: old value=0.0, new value=5.9, type=decimal
2018-11-22 09:49:35.046 Detail, Node003, Changes to this value are not verified
2018-11-22 09:49:35.046 Detail, Node003, Notification: ValueChanged
This is the OZW log when switching og two switches at the same time through a scrpt. There is a delay in the log from :24 to :34 where nothing happenes.
