So I’ve finally got this working… For those who are interested in how I got around my Door Station limitations using NginX reverse proxy, please read on…
server {
server_name myserverurl.com; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/myserverurl.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/myserverurl.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
location / {
proxy_pass http://192.168.4.249:8123;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
proxy_set_header X-Forwarded-Proto $scheme;
Everything up to here is as was with regards to the nginx configuration. But because my door station can’t set custom headers, I planned to pass the long lived access token (llat) as part of the querystring, so I created the following configuration which follows on directly from above. In simple terms, I read any existing Authorisation header that came from the client (so as not to break any normal calls that are able to set the Authorisation header) into a variable. Then if I see a query string argument for the value llat, I overwrite the variable with the query string value.
#Read any Authorisation header already received from the client as a default
set $my_client_auth_header $http_authorization;
#Conditionally overwrite the header values it if there is a querystring value for llat (long lived access token)
if ($arg_llat != '') {
set $my_client_auth_header "Bearer $arg_llat";
Then unfortunately after getting that all tested with Postman, I updated the url that the door station calls when the gate opens only to discover that it crashes if you put a long url in!!!
So I then basically had to take an approach which I didn’t want to originally as it requires storing a llat in the configuration file which I don’t want accidentally applied to any rogue incoming requests. Therefore, I have added a check on the client sending IP to make sure it’s come from the door station internally and if that matches, then to overwrite the Authorisation variable with the fixed llat value.
#Conditionally overwrite the header value if the call came from the DS2 door station (which can't support long URL's or headers!!!)
if ($remote_addr = "192.168.4.55") {
set $my_client_auth_header "Bearer my_long_lived_access_token"
Finally set an authorisation header in the proxied request using the value from the variable.
proxy_set_header Authorization $my_client_auth_header;
Issues that I see with this currently, is that if no Authorisation token was sent in the originating request, my changes here will add one regardless, although it will be blank if no llat is specified in the query string. Thus far I haven’t seen any negative effects from this, but it has only been in place for about 8 hours.
Additionally, the process above prefers a given query string llat over the posted header authorisation, this may not be desirable in all cases, but I think it’s obscure enough for my purposes.
Hopefully that helps someone. If anyone has any comments / suggestion, happy to receive feedback, it’s the first time I’ve done anything in Nginx beyond the standard setup.
For clarify, if you’re looking to repurpose this, cut and paste each of the code sections above as one whole block into your nginx config for your server to define the complete server section. Obviously the initial piece that defines the site should match what you have already so please edit to suit.
Cheers
