I’ve got a sensor I’m developing that will sound an alarm when something happens. I’ve got a physical momentary button wired to the GPIO and I have programmed a binary_sensor to read that input. When the button is pushed, it snoozes the alarm for a preset amount of time. This works great. Now I’m looking to add functionality to be able to cancel that snooze by long-pressing the same button. However, I don’t like the idea of setting up on_click
to a specified time because I want the siren to chirp to let me know that I’ve held the button long enough. Sort of like when you reset most consumer electronics devices: you hold the reset button until you see a light flash or hear a beep, and then you let go of the reset button. This is the behavior I desire.
I tried adding the while
block and all the code after it, but it didn’t seem to have any effect. Anyone have suggestions on what I’m doing wrong or a different method to achieve this?
binary_sensor:
# Physical snooze button for alarm (if primary pump isn't working)
- platform: gpio
pin:
number: 23
mode:
input: true
pullup: true
inverted: true
name: "${friendly_name} Alarm Snooze Physical Button"
internal: true
on_press:
# Set snooze by pressing the virtual snooze button
- button.press: virtual_snooze_button
# If the physical snooze is held, cancel the snooze after 3 sec & chirp the alarm
- while:
condition:
binary_sensor.is_on: physical_snooze_button
then:
- lambda: |-
static uint32_t begin_press = 0;
if (begin_press == 0) {
// button just pressed
begin_press = millis();
} else if (millis() - begin_press > 3000) {
// button held for 3s, so cancel the snooze
id(snooze_expiration_timestamp) = 0.0;
// Chirp the alarm so you know the snooze is reset
id(alarm_chirp).execute();
