This is the code to create long-term maximum and minimum sensors that read data from another sensor, temperature sensor in my case, but any sensor can be used.
It has these features:
- It removes wrong sensor values when the difference between new value and last one is higher than
input_number.max_temp_step
, which can be changed through Lovelace. - It can be reset by activating
input_boolean.reset_max_min
, which works as a dry contact through an automation. - It stores last update as an attribute.
- It self-initializes its value.
The code is:
template:
- trigger:
- platform: state
entity_id: sensor.pws_temp # Source sensor
- platform: state
entity_id: input_number.max_temp_step
- platform: state
entity_id: input_boolean.reset_max_min
to: "on"
- name: "Tª max Exterior"
state: >-
{% if ((state_attr('sensor.ta_max_exterior','last_valid_sensor_value')|float(states('sensor.pws_temp'))|float
- states('sensor.pws_temp')|float(-10))|abs < states('input_number.max_temp_step')|float)
and (states('sensor.pws_temp')|float > states('sensor.ta_max_exterior')|float(-10)) %}
{{ states('sensor.pws_temp') }}
{% else %}
{{ states('sensor.ta_max_exterior') }}
{% endif %}
unit_of_measurement: "ºC"
icon: mdi:thermometer-chevron-up
attributes:
last_update: >-
{{ now() }}
{% else %}
{{ state_attr('sensor.ta_max_exterior','last_update') }}
{% endif %}
last_valid_sensor_value: >-
- states('sensor.pws_temp')|float(-10))|abs < states('input_number.max_temp_step')|float) %}
{% else %}
{{ state_attr('sensor.ta_max_exterior','last_valid_sensor_value') }}
{% endif %}
- trigger:
- platform: state
entity_id: sensor.pws_vallad_temp
- platform: state
- platform: state
to: "on"
- name: "Tª min Exterior"
state: >-
{% if ((state_attr('sensor.ta_min_exterior','last_valid_sensor_value')|float(states('sensor.pws_temp'))|float
- states('sensor.pws_temp')|float(45))|abs < states('input_number.max_temp_step')|float)
and (states('sensor.pws_temp')|float < states('sensor.ta_min_exterior')|float(45)) %}
{% else %}
{{ states('sensor.ta_min_exterior') }}
{% endif %}
attributes:
last_update: >-
{{ now() }}
{% else %}
{{ state_attr('sensor.ta_min_exterior','last_update') }}
{% endif %}
- states('sensor.pws_temp')|float(45))|abs < states('input_number.max_temp_step')|float) %}
{% else %}
{{ state_attr('sensor.ta_min_exterior','last_valid_sensor_value') }}
{% endif %}
input_number:
max_temp_step:
name: Max temp step
min: 0
max: 20
initial: 5
input_boolean:
reset_max_min:
name: Reset max min
initial: False
icon: mdi:alert
automation:
- id: toggle_reset_min_max
alias: "Toggle reset_min_max"
description: "When input_boolean.reset_max_min is set to on, automatically set it to off after 2 seconds"
- platform: state
to: "on"
condition: []
- delay: '00:00:01'
- service: input_boolean.turn_off
mode: single
Edit: I’ve added default values to input sensors to avoid an unknown value distorted the state of the sensor.
