I want to create a sensor with long-term maximum temperature from another sensor.
By now, I have this in an input_number
instead of a sensor, with next code in a yaml package:
input_number:
ta_maxima_exterior:
name: Tª máxima exterior
icon: mdi:thermometer-chevron-up
unit_of_measurement: ºC
# initial: 10
min: 10
max: 48
step: 0.05
input_datetime:
fecha_ta_maxima_exterior:
name: Fecha Tª máxima exterior
has_date: true
has_time: true
automation:
- id: update_ta_max_exterior
alias: "Update Tª máxima exterior"
description: "Updates max temperature and date"
value_template: >-
{{states('sensor.pws_temp')|float >
states('input_number.ta_maxima_exterior')|float}}
condition: []
- service: input_number.set_value
value: >-
{{ states('sensor.pws_temp')}}
entity_id: input_number.ta_maxima_exterior
- service: input_datetime.set_datetime
timestamp: '{{ now().timestamp() }}'
entity_id: input_datetime.fecha_ta_maxima_exterior
mode: single
I’ve tried to create a sensor with the same behaviour (last_update will be stored in an atribute, but not coded until sensor works as intended) with template triggering like this:
template:
- unique_id: 'ta_maxima_exterior'
value_template: >-
states('sensor.ta_maxima_exterior')|float}}
- name: "Tª máxima exterior"
state: "{{ states('sensor.pws_temp')}}"
unit_of_measurement: 'ºC'
But it doesn’t work. I don’t know it the problem is using the sensor state inside the trigger.
In both cases, initialization of the maximum value is neccesary. In the ‘input_number’ solution, through manual triggering the automation, and in the sensor one, with update entity service.
Any help will be welcome.
I’m seeing that input_number
values are set to their initial value each time HA is restarted, so I’ve changed my actual solution removing initial
property of input_number
I’ve been able to make what I want whith this sensor:
template:
- trigger:
value_template: >-
states('sensor.ta_maxima_exterior')|float(-10)}}
- name: ta_maxima_exterior
unique_id: "ta_maxima_exterior"
state: "{{ states('sensor.pws_temp') }}"
unit_of_measurement: "ºC"
attributes:
last_update: "{{ now() }}"
The only problem is with initialization. If I initialize it manually in Developer Tools -> States -> Set State
. After the initialization it works fine.
My question now is whether there is a way to automatically (or with a script, or something like that) initialize this sensor after creation (or reset manually after some time).
I’ve found a solution to inizialization/reset with an input_boolean
, and a new trigger with platform state like this:
input_boolean:
reset_max_min:
name: Reset max min
initial: False
template:
- trigger:
value_template: >-
- platform: state
entity_id: input_boolean.reset_max_min
to: "on"
attributes:
The likelihood is that the reason it doesn’t work the way you want, is because you need a default value for BOTH floats - as sensor.pws_temp
probably doesn’t have a value when Home Assistant is loading in the YAML files - and will complain that it cannot convert ‘unknown’ to a float value.
{{ states('sensor.pws_temp')|float(-99) >
states('sensor.ta_maxima_exterior')|float(-10) }}
May go some way to solving some of your issues.
It doesn’t work for me. The problem is that the sensor on triggers when the condition in the trigger passes from false
to true
A working solution is in my previous post, with the input_boolean
Yeah if it was me - for the automation - I would have triggered on every state change of the sensor, and then used the condition to check if it was above the maximum always recorded.
Something like:
automation:
- platform: state
entity_id: sensor.pws_temp
condition:
value_template: >-
states('input_number.ta_maxima_exterior')|float(-99) }}
The problem is that template triggered sensor don’t have a condition clause.
That’s why I would have stuck with the automation - the example that I have posted would work fine, on the first state change of sensor.pws_temp
Just in case anybody finds it useful, here is the last version of the sensor.
It has these features:
- It does not need initialization.
- It removes wrong sensor values when the difference between new value and last one is higher than
input_number.max_temp_step
, which can be changed through Lovelace.
- It can be reset by activating
, which works as a dry contact through an automation.
- It stores last update as an attribute.
The code is:
template:
- trigger:
- platform: state
entity_id: sensor.pws_temp # Source sensor
- platform: state
entity_id: input_number.max_temp_step
- platform: state
to: "on"
- name: "Tª max Exterior"
state: >-
{% if ((state_attr('sensor.ta_max_exterior','last_valid_sensor_value')|float(states('sensor.pws_temp'))|float
- states('sensor.pws_temp')|float)|abs < states('input_number.max_temp_step')|float)
and (states('sensor.pws_temp')|float > states('sensor.ta_max_exterior')|float(-10)) %}
{% else %}
{{ states('sensor.ta_max_exterior') }}
{% endif %}
attributes:
last_update: >-
{{ now() }}
{% else %}
{{ state_attr('sensor.ta_max_exterior','last_update') }}
{% endif %}
last_valid_sensor_value: >-
- states('sensor.pws_temp')|float)|abs < states('input_number.max_temp_step')|float) %}
{% else %}
{{ state_attr('sensor.ta_max_exterior','last_valid_sensor_value') }}
{% endif %}
input_number:
max_temp_step:
name: Max temp step
min: 0
max: 20
initial: 5
input_boolean:
reset_max_min:
name: Reset max min
initial: False
icon: mdi:alert
automation:
- id: toggle_reset_min_max
alias: "Toggle reset_min_max"
description: "When input_boolean.reset_max_min is set to on, automatically set it to off after 2 seconds"
- platform: state
to: "on"
condition: []
- delay: '00:00:01'
- service: input_boolean.turn_off
mode: single
A long-term minimum temperature sensor can be done in a similar way:
- trigger:
- platform: state
entity_id: sensor.pws_vallad_temp
- platform: state
- platform: state
to: "on"
- name: "Tª min Exterior Valladolid"
state: >-
{% if ((state_attr('sensor.ta_min_exterior_valladolid','last_valid_sensor_value')|float(states('sensor.pws_vallad_temp'))|float
- states('sensor.pws_vallad_temp')|float)|abs < states('input_number.max_temp_step')|float)
and (states('sensor.pws_vallad_temp')|float < states('sensor.ta_min_exterior_valladolid')|float(45)) %}
{{ states('sensor.pws_vallad_temp') }}
{% else %}
{{ states('sensor.ta_min_exterior_valladolid') }}
{% endif %}
attributes:
last_update: >-
{{ now() }}
{% else %}
{{ state_attr('sensor.ta_min_exterior_valladolid','last_update') }}
{% endif %}
- states('sensor.pws_vallad_temp')|float)|abs < states('input_number.max_temp_step')|float) %}
{% else %}
{{ state_attr('sensor.ta_min_exterior_valladolid','last_valid_sensor_value') }}
{% endif %}
