I was replacing an old Centralite ZigBee Temp/Humidity Sensor with a new one. I delete the old one. I added the new one and gave it the same name as the old one. All seemed fine. Then I realized that I had lost my Long Term Statistics. Everything before exactly 5pm that day was gone. Weeks of data apparently deleted. Maybe a coincidence but I was changing the ZigBee sensor right around 5pm.
Anyone else ever experience a loss of their Long Term Statistics?
Thanks, Mike
Hey Mike –
It’s unclear (to me at least); did you lose long term statistics for all devices or long term statistics for the device you deleted?
All devices. Like the Long Term Statistics database was wiped at 5pm and started fresh.
Ouch! That’s what I was hoping you wouldn’t say!
Sorry man, hopefully someone more knowledgeable can chime in … I’m not even seeing an easy way to manually remove the long term stats, so you may have found a bug or some funky edge case.
Might be worth a shot just in case your browser is caching some filter or something: Try another browser or incognito mode to ensure it still isn’t showing.
For me, I take nightly backups of the VM and HASS itself triggers backups to my NAS a few times a week, so I’d probably roll back to whichever is more recent if I lost that data :-\
tom_l
March 17, 2024, 3:02am
5
There was an issue with renaming devices that causes database corruption.
A fix was merged into 2024.3.1. What version were you on when this renaming occured?
home-assistant:dev
← home-assistant:guard_db_corrupt_rename
opened 01:55PM - 08 Mar 24 UTC
## Proposed change
Describe the big picture of your changes here to com… municate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Guard against db corruption when renaming entities
- Add a the `filter_unique_constraint_integrity_error` safeguard to the entity registry rename
- Add the same safe guard we had in the states meta manager to the statistics meta manager
- Fix commit before and ensure it works as all our tests ran with a commit interval of zero
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [x] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #112414
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] I have followed the [perfect PR recommendations][perfect-pr]
- [ ] The code has been formatted using Ruff (`ruff format homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
tjhart85 - I had only started using HA a few months ago, so not too much data lost. Good advice re setting up backups. I have a NAS running and will set something up.
tom_l - I upgraded to 2024.3.1 after this problem occurred, so maybe this was it.
Thanks all, Mike
